lpg conversion for E300 td
matts124
New Registration
peterborough
w210 1999 300td
hi has anybody tried an lpg conversion for a w210 e300 td, in theory more power better economy and cleaner emissions. but what will it be like on the road???:confused::confused::rolleyes::rolleyes:
turbopete
Spennymoor
on a diesel, the benefits are negligeable. you still need to run something like 80%+ diesel and the power gains are limited by all accounts. certainly NOT worth the expense of the conversion unless you plan to do about 100k miles per year. they use the set up in the USA i gather on their HGV's but even THEY admit that in a car environment the gains will be virtually unnoticeable and certainly of no benefit.
Is this not the engine that runs well on fish and chip waste.
turbopete
Spennymoor
those old engines do run ok on cooking oil. perhaps i shouldve tried it in the one i had! dad ran the refined waste (converted to a biodiesel) in the cdi for about 40k miles with no issues. im almost tempted to try some again to see if it sorts a possible injector issue
Triv
Bristol
A brace of s210 1998 e300 turborustbuckets. Toyota HiLux Surf kzn185 3.0L
Why would you want to spend money to install a system that costs money to run?
As said above, these engines run fine on veg oil, which can be obtained for nothing and the only conversion cost will be a set of viton o rings at around a tenner.
It's a no brainer.
Having said that, I did meet a Dutchman last year who added nos systems to diesels with a trickle feed. Not for extra oomph but for economy.
He said that he'd had some very good results.
Makes sense to me.
Big Eb
london area
1999 E300 td avantgarde
Mine ran on biodiesel when i got it but not been able to soarce anymore, heathrow area
Tel: 020 8863 9233
