Lumbar Support inflates on its own
jhef
SLK 250 CDI 2013
I have an SLK which has started to do something rather odd over the past few months.
The lumbar support on the driver's seat inflates on its own, predominantly when I go around a left handed curve at speeds of over 20 or so MPH.
I have sent it in to the dealer to have a look at it and they cannot replicate it!
Has anyone else had a similar fault? Does anyone know of an easy way to disconnect/turn off the the lumbar pump so that I can stop this happening for the time being?
Do you have the dynamic seats fitted, you can turn this feature off in the menu.
I have it and do not like it at all.
jhef
SLK 250 CDI 2013
@Television- thank you for your response
Nope! No dynamic seats - it is an intermittent fault which happens from sideways forces.
It is probably due to a loose connection in either the switch or the pumping unit in the seat.
Interesting one as a valve has to open to let the air in,faulty switch maybe, the car is still under guarantee they must be able to fix it.
