Chazchuzzlewitt
- Nov 30, 2004
- Location
- Dorchester
- W/S124 320TE Estate
I've got an (I think engine-based) whine that starts dead-on 2000rpm and continues to around just under 3000rpm, which equates to 55-60mph in 4th gear. If I let the revs drop off to under 2000 it disappears. Isn't there if I slip into neutral at 60mph, so rev/engine speed dependant. Cruising at 70mph, at 3000prm, all is quiet again.
At first I thought might be bearing/gearbox/diff, but if I put it in neutral at 60mph (coasting downhill), it's silent again, but revving the engine while still in N past 2K I get the noise.
I've had the belt off and checked all accessories/pulleys etc, nothing untoward, belt & tensioner, alternator, idler pulley & fan pulley bracket all recent replacements (noise was there before all of these done), air/smog pump is removed.
Engine runs fine, no noise at idle, power good etc. Just that annoying whine.
The only thing I've read about that changes on the M104 at 2K is the VVT system, which is engaged at 2000rpm apparently...
Here's a sound recording of it, starts at around 5 secs in when I go over 2000 rpm, and you can hear it lessen as the revs go nearer 3k, then drop out again under 2k...
https://soundcloud.com/user-468757519/whiiiine
