M178 engine - break in period required?
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by E63S, Sep 12, 2017.
  1. E63S
    E63S Senior Member
    66
    Sep 10, 2017
    Your Mercedes:
    E63S W213
    I have ordered a new car with the M178 engine, as my first ever Mercedes. What are the general thoughts on breaking/running it in?
    A quick google search shows two schools of thought on Mercedes engines, running it in for 1,000 miles, 4.5k rpm max, 85mph max, and lots of engine braking, or alternatively, giving it the full beans from day 1. Unfortunately I couldn't find any specific guidance on this engine.
    Any help would be appreciated.
  2. Wighty
    Wighty Senior Member
    3,136
    1,036
    Aug 4, 2016
    Your Mercedes:
    If I was lucky enough to have one , I would do the first 1k easy if I planned to keep the car long term . Otherwise full beans from the forecourt with the traction off :D:D:D:eek:
  3. malcolm210
    malcolm210 Senior Member
    2,841
    197
    Aug 21, 2005
    The engine is hand built so I would expect the tolerances to be as good as it gets, bearing this in mind I wouldn't red line it before 1k miles but other than that it should be good to go
  4. LostKiwi
    LostKiwi Senior Member
    11,363
    3,747
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    What does it say in the owners manual?
    Personally I would drive it like you would normally only avoiding high throttle openings (hot spots the rings) and full redline runs.
    Drive it too gently and you risk glazing the bores, to hard and you introduce weaknesses into the rings.
    Full throttle from the outset is fine for race or competition engines which are regularly rebuilt but not road engines.
  5. daveenty
    daveenty Senior Member
    2,387
    372
    Jun 21, 2005
    The Frozen North :(
    Your Mercedes:
    2017 W213 E63s & 1989 W201 2.5-16
    There's a sticker on the windscreen advising the correct running in procedure which I would loosely stay with.
    Personally, I tend to take it easy for the first few hundred miles but varying the engine speed accordingly up to the recommended rev limit. The most important one to me is not to let it labour in a high gear at low revs.
    Also worth bearing in mind is that it's not just the engine you're bedding in, also the driveline including diffs and transmission, brakes and bearings throughout the car.
    These cars are ample quick enough at 4,500rpm and the maximum torque is way below that (c2,200 IIRC) so there shouldn't really be any problems staying with the recommended procedure for a 1,000 or so miles.
    Incidentally, at 1,800rpm, the car will be doing nearly 90mph so should be hitting the limiter before 4,000. :)
    Oh, I think it's a M177 engine, the M178 being the dry sump version as used in the GTS, though not 100%
    AMGeed likes this.
  6. OP
    E63S
    E63S Senior Member
    66
    Sep 10, 2017
    Your Mercedes:
    E63S W213
    Thanks for all the responses. I think I'll take it easy for the first 1,000 metres, then reassess. ;)
  7. LostKiwi
    11,363
    3,747
    Aug 25, 2006
    Your Mercedes:
    1000 metres....?
    daveenty likes this.
Share This Page
