jeepmerc
- Oct 19, 2017
- Jeep Compass with a OM651
Hi all,
I have a Jeep Compass that is using a MB OM651 2011 engine (OM651.925 I believe - paper style cartridge filters). The problem I am having is a timing chain rattle on start. Its not a new problem But I only really noticed it after getting the car and doing the first oil / filter change. Judging my oil the previous owner didn't take care of it.
- If drive the car and get it warm with a longer drive, then leave it some hours, I can almost guarantee I will get a timing chain slap / rattle on start. It lasts 2-3 seconds But doesnt sound at all good and I think more than just "nature of hydraulics" (as in, turns heads in the street noise)
- If I just start the car, let it turn over 15-20 mins or just do short 10 min driving runs then leave it some hours (or even days..or even weeks..) and turn on, I get no rattle or chain slap or at the most 1 second or so if its been sitting a very long while.
In any scenario, once started it goes like clockwork with no chain noise. I had a Merc engine specialist take a quick look and "it all sounds good" once running.
I would have said chain stretch But then I assume it would always rattle on start regardless..
What I have tried:
- Changed oil a few times (Castrol Magnatec 5w30)
- Changed filter with changing oil (Mahle OX153/7D2)
- Motor flush (LiquiMoly) - didn't see any sludge, plastic or bad stuff. just dirty oil
- Took a gamble on some LiquiMoly Ceratec oil additive having read the reviews
- Talked to a dealer who advised there had been a few revisions of the chain tensioner. I bought the latest revision (genuine Merc) and changed out the original (.. not a fun DIY job at the rear of the motor behind a heat shield). The holes are larger than the original which I assume helps oil in faster to build pressure But it looked the same length.
Changing the tensioner improved things from always slapping on cold start to this occasional slapping after driving a distance.
At this point I dont know what todo - changing guides and chain is an engine removal job and not really worth it. Not sure that would fix it even..
I guess I could try yet-another filter and oil change But this time try a quality 0w30 with the idea it should flow faster and get the tensioner pressure up sooner to minimise the slap ?
My assumption is once the engine is getting warm and being pushed with longer driving, the oil is flowing and properly circulating and that somehow leads to pressure dropping faster once cooled down hence takes longer to get to the tensioner.
Could it be an anti-drain back value is stuck open somewhere ? not sure where to look for it even.. could it be something in the oil filter housing ?
Any ideas much appreciated !
What I have tried:
