MB w205 C180 2015 Sunroof tilt problem
Discussion in 'General Mercedes-Benz Related Discussion' started by Bernardo Hernández, Dec 6, 2018 at 10:56 PM.
  1. Bernardo Hernández
    Bernardo Hernández New Member
    7
    Thursday
    Bogotá, Colombia SA
    Your Mercedes:
    MB C180/2015/w205
    Hi everyone, hope if someone has (I think!) this same problem, when I hold the sunroof button to tilt up the glass, at first it opens obout 4cms and immediately after closes to two cms, in other words, it does not maintain fully open. If I want to open it completely (tilt in the back) I have give several short touches to the control button. This is happening only when I try to open tilt the sunroof, opening it all back woks very well. I do not know if this a normal operation or is this an issue, could someone help me with this? thanks to all, best regards.
  2. John Laidlaw
    John Laidlaw Senior Member
    17,148
    4,079
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    May need a reset Bernardo
    I’m trying to remember the procedure for your model ...
    I think it’s close all doors and windows, key to pos 2, open sunroof fully and hold the button even though fully open until you hear a click...
    This is stretching my memory from when I had this model about 8 or so years ago!hope that helps
  3. OP
    Bernardo Hernández
    7
    Thursday
    Bogotá, Colombia SA
    Your Mercedes:
    MB C180/2015/w205
    Thank you John, I appreciate very much your help, I will try this operation and see if it works.
  4. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,433
    684
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    Mercedes-Benz C32AMG, SL55AMG, C320CDI Sport Edition Estate and SLR McLaren Coupe Roadster.
    Software update for this issue I believe.
  5. OP
    Bernardo Hernández
    7
    Thursday
    Bogotá, Colombia SA
    Your Mercedes:
    MB C180/2015/w205
    Well I did what John told me, "close all doors and windows, key to pos 2, open sunroof fully and hold the button even though fully open until you hear a click...", but nothing happen. When the ruf was totaly opene, I kept the button pushed for almos a minute, then I release it and push it back again, holding it for a minute, Well, for some reason this procedure does not work with this car. But I appreciate John's recomendation.
  6. John Laidlaw
    17,148
    4,079
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Damn! As Steve says then maybe it needs a software update via Star Xentry.. do you have an independent specialist nearby ?
  7. OP
    Bernardo Hernández
    7
    Thursday
    Bogotá, Colombia SA
    Your Mercedes:
    MB C180/2015/w205
    Its not easy to find an independent specialist here that has the software and interface computer , but I will try finding it. I could also go to the MB dealer here in Bogotà and ask how much does it cost for updating the car software, and to make a skaning procedure to verify options. Thanks John.
Share This Page
