Mercedes Atego Cab Tilt
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Rich_Allen, Feb 12, 2018.
  1. Rich_Allen
    Rich_Allen New Member
    3
    Aug 18, 2017
    Your Mercedes:
    Atego 18T 2001
    Evening all....
    After some help, I have a 2001 Atego horse lorry that I need to tilt the cab to get to the engine.
    Both hydraulic locks are released but the cab only lifts a few inches then stops and the pump goes hard and you struggle to push the bar down.
    Have I missed something to release it?
    Cheers
  2. XJ600
    XJ600 Active Member
    28
    7
    Feb 8, 2018
    Kentshire
    Your Mercedes:
    2011 S204 220CDI Sport Auto
    Have you opened the valve ?
  3. OP
    Rich_Allen
    3
    Aug 18, 2017
    Your Mercedes:
    Atego 18T 2001
    Yes, Valve seems to work opening and closing... Set to open the cab starts to go up and then just stops. Pump goes very hard as if there is big resistance..
    Last time the cab went up the pipe between the two locks split so they are currently disconnected, The pump is direct to the cab ram. I need to raise cab to fit new pipe etc.
  4. Ken_R
    Ken_R Senior Member
    626
    161
    Dec 11, 2015
    Worcestershire, UK
    Your Mercedes:
    W203 2006 C230 Estate
    Have you opened/raised the front grill panel? Not sure if it applies this model but certainly many others.
Share This Page
