Hi all,
Wondering if anybody can help...
Car is a 2007 fitted with xenon headlights. One bulb blew so I’ve set about replacing it. Easy enough to get to, remove the ballast/igniter (the unit connected the bulb which I’m guessing powers it) and the new bulb in place. Problem is, I can’t the ballast to click back to the ‘close’ position!! It was easy to remove, just a quarter turn towards the ‘open’ position. Is there a trick to this? It just doesn’t work want to turn towards the close position at all. There are 4 tabs on the unit, I’ve got these lined up with the receivers on the bulb holder unit but it won’t turn to close and I don’t want to force it too much...
Thanks in advance!
Martin
Thanks in advance!
Martin
