Russelld
Hello all, I am in desperate need of some help, my 2006 S class diesel is smoking really badly, you may have seen some of my other posts regarding this, another user - mercuser had the same problem as mine but the end solution to his problem was never posted on here, the car has just been in the Merc dealership for 5 weeks and no one could tell what was wrong as the car has no fault codes, there was damage to the turbo so I have replaced and also replaced injector no 6 (over 2k) to which we though was the problem solved, before this I had also changed the DPF with an aftermarket one, oxygen sensor upgrade, differential pressure sensor has been changed twice, temp sensor going into DPF has been done, the vehicle is a chauffeur car and it does not sit with the engine idling while waiting for clients as i know this is very bad for the DPF. Timing chain has also been replaced at main dealer.
Before changing the turbo and injector the car was smoking really badly with plumes of White blue smoke and had a really strong sulphur smell which would eventually come into the cabin of the car, now it is more a clear smoke, it happens when you have been driving then pull up to a stop then drive off again it blows smoke then it clears, car runs perfectly all the time but obv still something wrong?
I am thinking of getting the DPF mapped out of the ECU but I am very apprehensive about doing it, has anyone done this on this vehicle before or know somewhere that could do it for me, I am in Edinburgh Scotland.
Or can anyone shed light on the above or anything else i should change, I am demented with this car and need it for lots of work ASAP, also go on holiday on thurs and need it fixed before then?
PLEASE HELP !
PLEASE HELP !
