ML320 CDI Brabus Heating and Air con failure
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Angela Jay, Aug 13, 2018.
  1. Angela Jay
    Angela Jay New Member
    8
    Aug 13, 2018
    Your Mercedes:
    ML320 CDI Brabus
    Driving back home yesterday from Milton Keynes to Manchester, my heating panel died, no air con, no heating, no de misters.
    Engine became noisy like all the fans were on, managed to get home, but still doing the same this morning, only had it 2 weeks!!
    any ideas lads n lasses?
  2. LostKiwi
    LostKiwi Senior Member
    14,478
    5,694
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Have you checked fuses?
  3. OP
    Angela Jay
    8
    Aug 13, 2018
    Your Mercedes:
    ML320 CDI Brabus
    Yes, nothing problematic there, ive no error messages on dash display just a lot of noise like fans underneath the car and no lights on heating panel at all.
    Looked it up in owners manual and it says air con leak or re gas, doesnt mention anything about the extra noise.
  4. LostKiwi
    14,478
    5,694
    Aug 25, 2006
    Your Mercedes:
    The extra noise will be the electric cooling fans running at high speed (so aside from being noisy not a serious issue).
    The fans are controlled by the Aircon control panel. It sounds like the control unit has died or perhaps has a bad connection.
    Where are you located? We can suggest a good Mercedes specialist perhaps?
    Edit: just thinking about it did you buy from a used car dealer? If so you have some redress under the consumer rights act. Get them to fix it.
  5. Wighty
    Wighty Senior Member
    4,448
    1,938
    Aug 4, 2016
    Your Mercedes:
    If you have only had it 2 weeks and bourght from a dealer you should contact them to repair it first
  6. OP
    Angela Jay
    8
    Aug 13, 2018
    Your Mercedes:
    ML320 CDI Brabus
    Just been up to the dealers, weird though damn thing has started working again, could it have been damp or water ingress and it shorted out? The obd showed no fault codes?
  7. Craiglxviii
    Craiglxviii Senior Member
    13,165
    2,794
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    W215 CL500 Garage Queen; W211 E320 Avantgarde Estate Designo Edition
    The W163 ML-klasse is known for the AAM (All Activity Module) in the passenger footwell going a knacker and throwing up random issues..........
Share This Page
