MSL re-map.
Crispian
nuneaton
W166 Ml63 AMG with performance package
They use a correction factor of 1.18 for the transmission loss.
526 ft lb equates to 713 nm torque.
V6Matty
Newark, Nottinghamshire
Why is the graph power at the wheels when most quote flywheel ?
As is 295 & 526 flywheel .
Because the only way to get a flywheel figure is to remove the engine and have an engine dyno test, or has been done at MSL do the wheels and then convert using 1.18 to get as close to a flywheel figure as is reasonably possible.
Crispian
nuneaton
Suggest you don't believe the computer readout for mileage. Do a fill to fill calculation for real figures. Remaps are known for skewing mpg figures.
Yeah I thought that.
It's all about smiles per gallon ;-)
Gazwould
C250 CDI
Fair enough V6Matty , just a fan of
I didn't know remaps can give false mpg figures , tuning boxes for sure as they piggy back the ecu and the extra fuel they fool the ecu into providing isn't accounted for so more fuel going in but mpg shows a saving .
John Laidlaw
Wirral
Land Rover Discovery 4
MSL use Dyno Jet and do the conversion
I’ve had mine on Dyno Dynamics too at Riverside racing Liverpool - not much to choose except Acid and the boys have the skill to get the power down - at RR they struggled with mine
Gazwould
C250 CDI
Can't seem to find a list of vehicles and expected remap Stage 1 results on MSL .
Gazwould
C250 CDI
That's different , anyone had a OM651 250 CDI done ?
Gazwould
C250 CDI
Not quoting remap figures .
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
When I spoke to them they advised what they could take the engine to based on my requirements i.e. did i want an increase in power but also better MPG.
gurdip
E350 bluetech coupe
Absolutely it has!
The pre map output was around 261hp.
Obviously the power increase is evident,gearbox changes are smoother,slight increase in mpg,I was getting 35 ish around town,now showing 40 ish.
Makes the whole car more drivable.
Sounds like a may be tempted to do mine now lol
