My new love - CL500
Discussion in 'Introduce yourself' started by Ash Hussain, Oct 12, 2017.
  1. Ash Hussain
    Ash Hussain Member
    21
    3
    Oct 5, 2017
    Your Mercedes:
    Cl500 2003
    Hello guys,
    Im new here, bought myself a 2003 CL500 about 2 weeks ago.
    Other than taking out a business loan to pay for fuel, its a stunning machine.
    I picked it up with lowering pins installed, so sits wonderfully low to the ground and the exhaust baffles are removed, so I spend ALL my driving time listening to the various low frequencies the exhaust produces. :)
    It has a little rust around the passenger arch and around sunroof which I'll get sorted soon. And an annoying ABC Warning light (white) which appears at around 30mph sometimes but goes away after a re-boot. Its booked in with Wayne Gates for next week for them to have a look at.
    I've also removed the original stereo (luckily it didnt have the BOSE amp) CD changer, speakers and replaced with JL components and an Alpine head unit.
    Hope to get acquainted with you guys. :)
    Mic and Flyinspanner like this.
  2. Craiglxviii
    Craiglxviii Senior Member
    11,122
    1,612
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    W215 CL500 Garage Queen; W212 E220 AMG Night Edition; W211 E320 Avantgarde Estate Designo Edition
    Hello and welcome. I'm glad to see you're managing your expectations with regard to fuel efficiency (I see 22mpg average from mine) and that you're becoming acquainted with ABC. It will be your attention-seeking friend for years to come make no doubt!
    Now the serious bit. The "500" in the model designation doesn't refer to tne engine size, but the numerator for individual repair jobs. That is, expect your repair jobs to be in multiples of £500 and you won't go wrong. A sensible budget for repair and maintenance each year is £2000- £2500.
    I would very strongly suggest that you have the lowering links removed, ABC doesn't like them and they can cause many problems (they may be part of the cause of your warning). The car sits low enough in its arches on 18" wheels with ride height set to standard anyway.
    Ash Hussain likes this.
  3. OP
    Ash Hussain
    Ash Hussain Member
    21
    3
    Oct 5, 2017
    Your Mercedes:
    Cl500 2003
    Thanks very much for your response. :)
    I took the cost of servicing onboard before I purchased. Previous cars have included an M5, M3 and 335i convertible. So am well acquainted with ridiculous repair costs.
    I have the original links so if that is the problem I'll have them put back in again and go for bigger wheels. :)
  4. LostKiwi
    LostKiwi Senior Member
    9,477
    2,690
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500, 04 Smart Roadster Coupe
    Hi and welcome - the CL is a fine and majestic vehicle and has some serious engineering in it (those door hinges for example!)
  5. Flyinspanner
    Flyinspanner Senior Member
    918
    125
    Aug 8, 2010
    Ruislip
    Your Mercedes:
    CL500 -W215, A140-W168
    Terry at WG is a great guy to have onside, and will be able to sort the niggles out. As I mentioned on the other thread, it's a good idea to get the system flushed, (every 2-3 years is a good preventative measure, as it keeps it all very clean).
    With regard to 'rust', I assume you have some paint bubbles? It is corrosion, but most panels are aluminium, front wings and boot lid are plastic.
    There is a Bodyshop in Park Royal that gets good reports, can't remember the name at the moment.
    Mine is on 19", standard suspension, and the stance looks good.
    Pullman and Ash Hussain like this.
  6. Craiglxviii
    11,122
    1,612
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    When I say cost of servicing, bear in mind:
    ABC pump replacement = £700.
    ABC strut replacement = £1100/ corner.
    Rear ABC solid/ flexi hose replacement = £350
    A/C compressor replacement = £1100.
    ABC valve block replacement = £1400.
    ABC valve block rebuild = £350.
    I strongly advise not going over 18” on wheel size. This gives you a depth profile of 40 for and 35 rr on staggered wheels. You will have around 35mm from tyre to top of arch and you really need it on the less than 3rd World road surfaces we have.
  7. Craiglxviii
    11,122
    1,612
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    Those are luvverly wheels FS!
    Ash Hussain and Flyinspanner like this.
  8. OP
    Ash Hussain
    Ash Hussain Member
    21
    3
    Oct 5, 2017
    Your Mercedes:
    Cl500 2003
    Thats a stunning machine. I'm going to consider having the standard links put back in. Hopefully that will cure the ABC issues.
    Yes, some paint bubbles... not too bad... I live in Slough so plenty of paint shops. I'll have it looked at after I get the ABC sorted. :)
    Flyinspanner likes this.
  9. OP
    Ash Hussain
    Ash Hussain Member
    21
    3
    Oct 5, 2017
    Your Mercedes:
    Cl500 2003
    seems as if the ABC is the biggest pain in the arse. lol
    I'll have the system serviced. Hopefully will continue without giving me any serious problems.
  10. Craiglxviii
    11,122
    1,612
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    You need to have it flushed and the filter replaced every 2 years or 20k miles religiously. Total cost (you can do this at home) is around £300, mainly for the Pentosin CHF.11S fluid (keep an eye out for this if on offer on eBay/ Opie Oils etc. £16/ litre is a good price, MB sell for £22/ litre, you need 10 litres).
    S5000L and Ash Hussain like this.
  11. Naraic
    Naraic Moderator
    9,263
    311
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Interesting C...I've been running lowering links for more than a year with no problems.
  12. Craiglxviii
    11,122
    1,612
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    Really? That IS interesting. yes, it's what I was told when my car first had its... "issues"... examined. Something to do with the plunger sensor calibration IIRC.
  13. OP
    Ash Hussain
    Ash Hussain Member
    21
    3
    Oct 5, 2017
    Your Mercedes:
    Cl500 2003
    currently the biggest issue I have is the rear view mirror doesn't save the settings... so always goes of to a different setting every time I start the car.
  14. Craiglxviii
    11,122
    1,612
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    That's odd. Settings are saved in the driver's seat control module.
  15. OP
    Ash Hussain
    Ash Hussain Member
    21
    3
    Oct 5, 2017
    Your Mercedes:
    Cl500 2003
    I'll have another play with it, but steering, seat and side mirrors save the settings fine. Just the rear view mirror doesnt.
  16. John Laidlaw
    John Laidlaw Senior Member
    11,565
    1,783
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    Welcome Ash, I’m late to the party but all the ABC stuff has been covered already by Craig...happy days!
  17. OP
    Ash Hussain
    Ash Hussain Member
    21
    3
    Oct 5, 2017
    Your Mercedes:
    Cl500 2003
    Thanks John! :)
  18. AJD
    AJD Senior Member
    3,035
    334
    May 31, 2015
    Suffolk by the Sea, UK.
    Your Mercedes:
    2012 W204 Sport ///AMG Line 4dr Auto, Obsidian Black.
    Hi Ash, welcome to the forum :)
  19. flowrider99
    flowrider99 Senior Member
    1,627
    259
    Jul 21, 2014
    Your Mercedes:
    SL500 (R230)
    Welcome to the forum.
  20. Naraic
    Naraic Moderator
    9,263
    311
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    My rvm isn't part of the automatic adjustments. Does your rvm move when you start the engine?
Share This Page
