My new love - CL500
Naraic
2005 CL500.
Certainly they could be got for the W215...from where I know not.
Interestingly within the strut there is a coil spring:
ajlsl600
france
which strut is that a rear ... i think any block would have to be like a bump stop between the lower arm and.....
ajlsl600
france
Yeah thats a rear but the front is similar.
thought so could not see ball joint ,part of front strut.another grand design.no
Indded. Having said that I can't see why it shouldn't be possible to press in a new balljoint assuming one is available in the right size (from looking at my spare front strut).
Craiglxviii
Cambs UK
We started studying this on the forum right when I first joined. The conclusion was that pressing in a new ball joint would be entirely possible and cost around £150 a corner all told- for the 215. New balljoints are available for the 230 already and it's those that seem to wear out, not so much on the 215.
Naraic
2005 CL500.
It's a front one for the W215. Indeed it was a block fitted above the upper arm.
ajlsl600
france
ajlsl600
france
lk i did some research on that about 2 yr ago ,posts on here somewhere ,i found a site offering them ,i seem to remember about 160 euro each ,but out of stock and never able to advise when they would have stock .i to sure it can be done, suspect benz interfered with supply , which prob was same as benz outsource at that time its on here just dont know where as i dont think i started the subject .
ajlsl600
france
lk found that https://www.abcteile24.de/shop/ see if you can scroll down past all the struts and pumps . the origional subject was lower abc strut ball joint july 19 2016 ajlsl600
ajlsl600
france
where did you see new ball joints for r230 i only saw the ones from a non abc strut cut out and the ones mentioned just now to lk
Craiglxviii
Cambs UK
Don't use them, don't trust them. I still have a €480 pump that failed within 3 days that they've refused to honour their warranty on.
ajlsl600
france
great. must go in from the top. and once in simply cant get out. q is.. is the knurled dia right .anyone used them yet.
ajlsl600
france
right, reply as was typing mine. lets see if anyone had any result with them on his issue and on pump what were the grounds for refusal of warranty.
flowrider
SL500 (R230)
i dont want a stripped out car either nor do i want to be stuck on the side of the road watching a french recovery vehicle tearing the bottom out of my 38,000 mile car because its arse is on the ground and his transporter ramps are not correct for the job. now i would prefer it much more if benz had thought more on that and given the girating mirror a miss . harped on about this before, i retire early next yr and i will ,if i get bored, develop my own metalastic type blocks that can be fitted in such an event, my own version of the plastic shift lock, and a permanent solution to having keyless go turning me into a form filling pedestrian ,should someone develop a decent coil over for the r230 i will investigate that too. tho i would not change abc until i was looking at replacement pump,struts ect of course i could just buy a SL350 ,but the v doz is a silky motor of note ,thats my weak spot for this delightfully styled car.
Replacing the ABC with coilovers...............
