no air from vents = blocked pollen filter
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by lambert04, Dec 18, 2006.
  1. lambert04
    lambert04 New Member
    Jul 14, 2006
    sheffield. uk
    lack of air coming out of vents = blocked pollen filter.
    just done mine too (thanks for the tips)
    thought i would break it down step by step.
    first remove the centre console that connects the dash to the floor (box shape) by unscrewing the two 10mm plastic bolts either side of the console. now look up inside the dash, you will see two metal rods, and a big black box. at the back of this box (nearest the engine) is the pollen filter cover.its only a thin strip of plastic. mine was about 12inch long and had this type of pattern on it [X[X[X[X[X[. the pollen filter is under this cover. it slides towards the passenger door (right hand drive van) about two to three inch. it should pull/drop then off. i had to hit it to make it slide with the hook end of a small crow bar between the two metal rods. i then put a long flat screw driver into the corner of the plastic base of the filter and prised it out a bit. then i pulled out the filter. (it broke as it came out). its quite fiddly to get it out though. takes a bit of time. make sure when your pulling it out to move the thin grey wire that runs near it.....
    hope this is helps..
  2. television
    television Always remembered RIP
    164,092
    193
    Your Mercedes:
    Any chance that you could re do it and include the car details,then it can be uesd for reference.
    malcolm
  3. C220GJS
    C220GJS Senior Member
    1,021
    Feb 13, 2006
    Shotts, Scotland.
    Your Mercedes:
    1995 W202 C220 Elegance
    Being psychic I can tell that this is a Vito 108 CDI, sorry can't make out the year.:rolleyes:
  4. Blobcat
    Blobcat Moderator
    7,905
    21
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    W213 E220d, Smart R451 CDI, Porsche 911 C2S, Land Rover 110 County SW
    I will have a stab at an 2002 Vito 108 CDI ;) :p
  5. C220GJS
    1,021
    Feb 13, 2006
    Shotts, Scotland.
    Your Mercedes:
  6. OP
    lambert04
    Jul 14, 2006
    sheffield. uk
    sorry, its a vito 02 plate. 110cdi hope this helps you all out.
  7. C220GJS
    1,021
    Feb 13, 2006
    Shotts, Scotland.
    Your Mercedes:
  8. simon 4166
    simon 4166 New Member
    5
    Feb 8, 2007
    Great piece of advice, my heater was rubbish and the whole dash used to vibrate when the fan was on flat out, i ripped out the filter and it is great now!
    If anyone is going to do this, i used and allen key to hook the filter out and it worked a treat!
    Si
Share This Page
