Mark D
- Sep 21, 2017
- Location
- United States, Georgia
- 06 e320 CDI, 290k miles
Hey guys -
Got an issue with my 06 320 CDI inline 6. She has 260k miles. One day she was fine, the next morning I have a loss of power and a CEL. She runs ok but no boost when you hit the pedal.
Codes were:
P0243 - Turbo wastegate malfunction
P2009 - fuel water content sensor.(fuel filter)
P0489 - Exhaust gas recirculation control short to earth
P0102A - Mass or Volume Air Flow Circuit Low Input
The descriptions are what I got off the web but I'm not 100% sure for my car.
And I had a Coolant Temp alert on the dash but the coolant was fine. All of this made me think there might be a fuse blown.
Since then, I've done more trouble shooting and made some progress. I put a new MAF on. I found Fuse 44 blown, replace it and it blew again. It appears this is for the turbo actuator, among others. I replaced the fuse and took the linkage off the turbo actuator to see whether the Turbo was locked up or whether the actuator was bad. The turbo moves freely and the actuator appears to work. I put the linkage back on and when I start the engine, the actuator pulls the lever down for a few seconds and then pushes it all the way up. I'm almost positive it did not do this before I took the lever off (I looked to see). It's almost like the actuator was unable to move the turbo before ( causing the fuse to blow) and then after I removed the linkage and put it back, it got better and its not blowing the fuse.
I thought it might be fixed but when I took it on a test drive, it still don't have the thrust I used to have when you hit the gas. There were NO Codes showing in the test drive but it was only about 5 miles. Fuse 44 and the associated actuator was definitely part of the problem but she's still not working right. I don't know what conditions the turbo operates completely so I'm not sure its working properly. While in park, if you hit the pedal hard, the turbo actuator is not moving but I don't know if it should under those conditions. It has not been in limp mode at any time during this.
What else can be going on that it causing me to get no boost when I hit the gas?
Thanks guys!
Mark
Codes were:
Thanks guys!
Mark
