O-rings for radiator
Discussion in 'Spares for Sale and Wanted' started by Donald McPherson, Dec 31, 2018.
  1. Donald McPherson
    Donald McPherson Active Member
    41
    19
    Oct 20, 2018
    Your Mercedes:
    c180 komp elegance se a 2005
    Anyone know where I can get the O-rings or size for the ATF connector that goes into the radiator of my C Class kompressor W203?
  2. Westheath
    Westheath Senior Member
    1,437
    446
    Nov 6, 2015
    South London
    Your Mercedes:
    I have bought the replacement green and blue ones from Mercedes in the past and found they still leak
    on W211 and W203 probably due to wear/corrosion on the pipes or radiator sealing surfaces. .
    Feel free to make the repair using OEM you may be ok. 2 x A0289976248
    Mercedes response (and probably MB Independents) was replace the radiator and transmission pipes if the OEM part don't work.
    I use a generic 7x2 O ring from a mixed box slightly thicker than the blue OEM one.
    Please do not bodge this using silicone sealant when reassembling,
    just a light smear of LM grease on the O rings
    The camera perspective makes it look the opposite in the picture though :)
  3. OP
    Donald McPherson
    41
    19
    Oct 20, 2018
    Your Mercedes:
    Thanks. I will also order a mixed box as the price is not much more than ordering just two.
  4. om613
    om613 Senior Member
    1,299
    242
    Aug 29, 2015
    london
    Your Mercedes:
    S202 C250TD, S123 240TD
    Five 7x2 o-rings will cost you £2 (via a very good Ebay shop).
    A big box is handy to have, though.
Share This Page
