wizzman
- Nov 25, 2015
- Location
- Grimsby, NE Lincolnshire
- SL500 2002
Right, I know what you are all thinking but after removing all under shields, headlamps, bumper, front wheels I have found the cause and it is not an ABC pipe but a pipe which runs from the bell housing to the R/H side of the radiator, presumably a transmission fluid cooler pipe. I have never come across ATF that is green, Is this correct ? . The pipe looks like a right pig to remove. Any tips ?
The car is overdue a service and while I have it stripped down I plan to re-o-ring the front and rear ABC valve blocks and flush etc so Craig, could you pm me with some details so I can get a couple of kits from you ? cheers. The car drops over a few days but recently it can go down in a matter of hours. Got a rusty accumulator as well. Best place for one of those anyone ?
thanks for any help/advice
Ian
Ian
