Hi there I have a small question. Is it possiable for me to change the oil and filter myself? Or do I have to take it to a dealer? I have heard you need to reset something?
Newer models with the ASSYST service indicator will require that the system is reset after the oil change/service so that it can start an new countdown to the next.
There used to be a re-setting tool for BMW's available, which grounded a specific pin in the diagnostics socket. I don't know however, what is required with ASSYST in order to re-set it.
If you have an older model, then there's nothing to reset as the service is scheduled according to fixed mileage intervals.
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
