chris cross
- Mar 18, 2009
Got a Mercedes Sprinter 312. Noticed the other day oil dripping underneath it. Switched off engine and investigated. Oil on dipstick is within limits but lower than normal. No creamy deposits or water appears present. If i dip my finger in radiator header tank its just pure thick black oil. Started engine again, engine appears to run and rev fine. Was never overheating or knocking. Realised that drips of oil originally seen were coming from radiator overflow. Shut down engine again after only 30 seconds or so. Then removed top hose at engine end to find thick black oil running out?
Someone has told me it could be head gasket or oil cooler failed. I'm struggling to believe its head gasket as oil all seems to be in the water in a big way with no real signs of water being in the oil.
I'm at a loss with this and would appreciate opinions or advice from other members. Engine has covered around 250,000 so not high for one of these.
