Oil labelling explained
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by oilman, Jun 27, 2006.
  1. Dale Minton
    Dale Minton Senior Member
    595
    5
    Dec 17, 2008
    Your Mercedes:
    SL55 AMG & BMW ALPINA D10 BiTurbo
    Thanks Tim, appreciated. I posted this to our other forum friends who on another thread were discussing the pros and cons of it's use. I hope they will find it helpful.
    Dale.
  2. Jimbo1959
    Jimbo1959 Senior Member
    173
    101
    Mar 22, 2018
    Ayrshire
    Your Mercedes:
    E350 CDi Blue Efficiency Sport Coupe, fast, smooth and comfortable, wunderbar machine!!
    There is so much information delivered here that I'm starting to get confused, so, if Tim, (oilman) could clarify please!!!
    I have an '09 E 350 CDi Sport Coupe which I am assured has a DPF fitted. From my reading on here and the owners manual I should use either 5W/30 or 0W/40 which meets 229.31 or 229.51.
    Have I worked it out properly Tim?
    One final question sir, Does it really matter which brand I purchase as long as the particular specification is met?
    The reason I ask is that, at work, they use mainly Coma oils although, I can also get Mobil 1 if necessary.
  3. John Laidlaw
    John Laidlaw Senior Member
    12,980
    2,317
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    In case Tim doesn’t pick up on this Jim, you need the Low ash oil 229.51 for your car and provided the oil meets this MB specification and is approved to that then it doesn’t matter which brand, Comma, Mobil, Shell, Fuchs or whatever.
    Until recently MB were very competitive strangely but I’m informed less so now. That said I’d still try MB Grangemouth or of course the sponsor on here , Opie oils.
    Jimbo1959 likes this.
  4. Jimbo1959
    173
    101
    Mar 22, 2018
    Ayrshire
    Your Mercedes:
    Thanks John, Being a total novice on MB I thought it'd be a good idea to ask, and confirm, rather than just dive in head first and possibly make a mistake. With a car of this value it's better to be safe rather than sorry.
  5. John Laidlaw
    12,980
    2,317
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Not a problem , wise to be safe. Lovely cars deserve this strategy!
  6. OP
    oilman
    oilman Forum Supporter Authorised Forum Supporter
    681
    7
    Aug 13, 2004
    Sunny Cornwall
    Your Mercedes:
    clk 2008
    John Laidlaw likes this.
  7. Wighty
    Wighty Senior Member
    3,136
    1,036
    Aug 4, 2016
    Your Mercedes:
    If your car has a dpf , the inside of the exhaust tip is clean , if it doesn't it's black and sooty . Yes you do need 229.51 as said above . If you search 229.51 oil on eBay you can get 20 Liters of MB Branded oil for £60 delivered from a lot of the Merc dealers .
  8. Wighty
    3,136
    1,036
    Aug 4, 2016
    Your Mercedes:
    Looks like all 20L containers of 229.51 5w/30 MB oil have now disappeared from eBay :( (at least in the £60 region ) ...there are some ripoff ones for £200 .
  9. EXMERCTECH
    EXMERCTECH Senior Member
    119
    8
    Aug 7, 2003
    Sutton,Surrey.
    Your Mercedes:
    C320 V6 Diesel 2005
    Mr Oilman.
    There's a thread going round about using motorcycle oil 20/60
    In the Mercedes with the 642 engine with DPF
    Basically saying IIRC the recommend oil is too thin.
    I'll try and find the original post.
    What's you view on Motorcycle oil in a diesel with DPF.
    Phill.
    (Ex Dolomite Sprint V8 Owner.)
  10. OP
    oilman
    681
    7
    Aug 13, 2004
    Sunny Cornwall
    Your Mercedes:
    clk 2008
    Hi Phill
    Not a good idea. Bike oils are not formulated for DPFs and a 20w-60 is completely the wrong grade, offering very little cold start protection and is also very thick when hot, reducing protection and efficiency as well as putting more strain on the components.
    Okay, a 20w-60 is not going to burn off much, so might not affect the DPF much, but using such a thick oil is not going to help the oil.
    Cheers
    Tim
Share This Page
