mikembman
I'd be grateful of some advice. In the process of fixing my 2006 C180K for another problem I noticed there is oil leaking from one of the banjo bolts on the side of the transmission - the one about half way up on the driver's side so it looks like I need to replace the sealing washers. My question is, do I need to drain the transmission fluid first before I remove the banjo bolt - I've only just had the fluid the changed - or will I be able to change the washers without losing too much fluid?
Thanks,
mike
Thanks,
mike
