Lingwood
Hi noticed a couple weeping leaks on what I think is the turbo inter cooler?
Car is 2010 bluetec w212
The main leak is on the alloy pipe as in goes down the front. There appears to be a joint there behind the colt hose.
I have also noticed a bit of oil muck on the main body of the turbo from the intake around a orange seal.
I have read this is sort of normal, oil is ok and these leaks are not showing as drips on my garage floor.
Can someone identify what seals I might by to change and if it is a reasonable change to get out the alloy pipe...it looks fairly simple?
