Oil pouring from exhaust
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Alaska, Apr 12, 2018.
Tags:
  1. Alaska
    Alaska Member
    13
    May 13, 2013
    gloucester
    Your Mercedes:
    eclass 03 320
    Hi, I have a 2003 w211 e320cdi, I've just got my car back from the garage, I had the turbo reconditioned and there is now oil dripping out of the exhaust, is this a result of the turbo going before the recon and this just needs to clear, or is it a case of the turbo not being put back in right, or something different that caused the turbo to go in the 1st place?
    There is a lot of oil...
    Jim2 likes this.
  2. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,604
    777
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    Mercedes-Benz C32AMG, SL55AMG, C320CDI Sport Edition Estate and SLR McLaren Coupe Roadster.
    That is hard to say, it could be oil in the intercooler and exhaust being cycled out, but to be sure, I would have them pick it up on a low loader. I wouldn't drive it. Either its pumping oil out the turbo, which the way you describe, could end up running the oil too low, or you risk the oil being sucked up into the air intake via the turbo and it running on its own oil until it blows up.
    Jim2 likes this.
  3. bembo449
    bembo449 Senior Member
    2,666
    475
    Jan 2, 2012
    lincolnshire
    Your Mercedes:
    216 5.5 v8 , range rover vogue , 221 320cdi , alfa romeo brera
    as above , do not drive it any further , I get the feeling the turbo must really have blown badly and passed a lot of oil into the exhaust , cant say ive seen it before on any car let alone a merc but it doesn't sound good at all
    Jim2 likes this.
  4. Westheath
    Westheath Senior Member
    1,440
    449
    Nov 6, 2015
    South London
    Your Mercedes:
    Just done an Audi A5 turbo replacement, removed the exhaust system
    and steam cleaned it through after draining nearly 2 litres of oil out of it.
    Not that common but have had it before on a TT and Insignia.
    Craiglxviii, Jim2 and bembo449 like this.
  5. bembo449
    2,666
    475
    Jan 2, 2012
    lincolnshire
    Your Mercedes:
    think weve upset the OP ! not been on since
    alexanderfoti, Jim2 and amustali like this.
  6. OP
    Alaska
    Alaska Member
    13
    May 13, 2013
    gloucester
    Your Mercedes:
    eclass 03 320
    Sorry I haven't responded, I didn't get any notifications that I had any replies to my post.
    Ok I've discovered if I remove the engine breather pipe ( small plastic pipe coming from front of engine to air intake pipe to the turbo) no oil comes from the exhaust the moment I reconnect it oil drips from the exhaust, does anyone know what would cause the turbo to suck oil from the engine breather pipe.
    Jim2 likes this.
  7. LostKiwi
    LostKiwi Senior Member
    15,067
    6,111
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Do not run the engine. If there is that much oil there is a serious risk of diesel runaway where the engine runs on the oil in the inlet. If that happens you will almost certainly destroy the engine.
    Jim2 likes this.
  8. Taffy7hfa
    Taffy7hfa Senior Member
    805
    178
    May 29, 2016
    Oxford
    Your Mercedes:
    ML 270CDI 2002 Fully loaded. 2014 Peugeot 308 1.6 HDI. 2012 Suzuki Alto.
    The pipe you disconnected from your turbo air intake pipe is part of the crank case re-breather system, this union allows crank-case pressure or cylinder “blow by” gases to be mixed in with the intake air stream before it enters the turbo, some oil may enter the turbocharger from the re-breather system, however if there is a lot as your describing it may be that your oil separator is not working correctly.
    As stated above, to have oil visible in your exhaust pipe is very bad and often indicates that your turbo is shot, if you continue to drive it as it is, the engine may start to run on its own oil, which usually ends in catastrophic engine failure..
    Jim2 likes this.
  9. umblecumbuz
    umblecumbuz Senior Member
    3,239
    621
    Sep 20, 2010
    Wales and Gozo
    Your Mercedes:
    S204 and CLC 204 cdi, other non-Merc machines
    Are we to presume that your car is an automatic?
    If it's a manual, you have more control over the stopping of the engine in an emergency.
    Jim2 likes this.
  10. Westheath
    1,440
    449
    Nov 6, 2015
    South London
    Your Mercedes:
    Turbo seals have gone.
  11. OP
    Alaska
    Alaska Member
    13
    May 13, 2013
    gloucester
    Your Mercedes:
    eclass 03 320
    Yes it's auto and I've just had the turbo reconditioned
  12. alexanderfoti
    alexanderfoti MBO Forum Supporter Authorised Forum Supporter
    10,525
    1,271
    Mar 25, 2010
    Dartford
    Your Mercedes:
    Take it back go the garage!?
    Unless it was leaking oil out the exhaust before you replaced the turbo?
    What symptoms did it have to be booked into the garage in the first place?
    stwat likes this.
  13. Westheath
    1,440
    449
    Nov 6, 2015
    South London
    Your Mercedes:
    Hang on...................... I retract my second post regarding turbo seals have gone,
    I just realized that I posted that the exhaust is probably full of oil.
  14. rapide
    rapide Senior Member
    639
    3
    Mar 9, 2008
    west sussex
    Your Mercedes:
    1997 E230 (no rust) 2016 volvo xc60 r/design. se. lux. nav.
    I changed a blown turbo on a saab years ago! and had to take off the exhaust system and wash it through it was full of engine oil! possibly you have the same problem!
Share This Page
