- Mar 25, 2010
- Location
- Tonbridge
- W221 S65 AMG - W204 C63 AMG + Various other MB's
- Moderator
- #21
All straight forward to remove and refit. Just common sense. Keep in mind the wheels will need to be in the air otherwise you will push the fluid out of the struts when disconnected.
To bleed afterwards you should be ok just raising/lowering the car a few times. Ideally you would run a rodeo on Star but I would say its not necessary as long as you plug the hoses when disconnected and minimise fluid loss.
