Oil sump seal
Status
Not open for further replies.
Will
I need some advice, the oil sump seal for the turbo oil return line needs to be replaced with the associated O rings. However the pipe won't trombone sufficiently to allow removal to install the required parts. If anyone knows a trick or two about removing the turbo, I would appreciate it.
W
Will
  • #2
It will come out with a little force and a lot of twisting. Once you grind a little off the tube that fits into the sump it will fit a lot easier.
thomas
Glasgow
This line is not under pressure so you could hacksaw it off and joint it with a rubber tube and Jubilee clips.
W
Will
Thanks for the help guys, I managed to get it off no problems. :)
Status
