zedmeister
- Sep 5, 2005
- Location
- Watford, Herts.
- CLK C208/2002/3.2, C Class S205/2019/220d, E class cab A124/1996/2.2
Still having trouble with my car - as a standard diesel, it jerks with lack of power only when cold. When warm it runs fine. When the Brabus D6 unit is refitted it is completely undriveable as the jerking occurs even at half throttle and then throws the engine management light on with the following fault:
2047 Rail pressure monitoring via volume control valve The rail pressure is too low.
Indie suggests fitting a new common rail with sensor on the drivers side (right side). They are around £600 but he is not sure if it will fix the issue.
Can the sensor be bought without the rail? Do you guys think this is the issue?
