Sandgrounder007
- Jun 26, 2017
- 2005, C320 CDI
Hi, I've been puting this off for months now but as cooler mornings aren't far away I need help. My c320 cdi is slow starting, to much cranking, I fitted a set of Bosch heater plugs then a new (Beru) relay, then a second relay, all with no improvement. I've done a little research which revealed the heater plugs require 4.5 volts, when I check the supply at the plug cap it's exactly 2 volts, the large supply cable to the relay is 12.5v so I'm looking for answers as to where the missing 2.5v have gone, can anyone help or am I barking up the wrong tree? When I plugged one of the old plugs in, just before it timed off it was just starting to glow red but nowhere near bright red or white. When cold, the glow plug light stays on for about a minute when I drive off.
Thanks in anticipation.
