OM651 E220 2014 - Oil leak under load?
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Christopher Martino, Nov 7, 2018.
  1. Christopher Martino
    Christopher Martino Active Member
    25
    3
    Jun 4, 2018
    Your Mercedes:
    E220 2014 2.2
    I've got a strange issue. My E220 had it's timing chain/guides done (full engine removal) along with a new clutch and flywheel a few weeks ago, since then it's developed an oil leak.
    I've ruled out crankshaft oil seal, and the cam case gasket has been replaced too. The oil leak seams to be coming from above the gearbox to either the left or the right hand side, it's hard to tell.
    It won't leak if its left sat idling, doesn't matter how long you leave, or how high you keep the engine RPM it's only when its being driven for some reason, and its fairly heavy when it is driven, pools in the under trays etc.
    Anybody have any experience on similar symptoms etc? The garage who carried out he work have been great, but we're having a bit of trouble locating the leak, I was hoping some of you gurus on here may have had similar symptoms or could perhaps pass an opinion on what you may think be causing it?
    Thanks for your time.
    Chris
  2. John Laidlaw
    John Laidlaw Senior Member
    17,666
    4,319
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
    Would have been thinking turbo inlet seals if you hadn’t mentioned no dripping whilst idling, however the guys who did your timing chain and sprockets would be experienced enough to check that surely.
    Definetely oil?
  3. OP
    Christopher Martino
    25
    3
    Jun 4, 2018
    Your Mercedes:
    E220 2014 2.2
    Hi John,
    Thanks for the reply, it's definitely oil. centre undertray was swimming in it, along with all along the bottom of the sump and front engine brace, it's not obvious where it's coming from.
    They're still investigating, I think one of the mechanics is going to drive it home and see.
  4. PaulG
    PaulG Senior Member
    779
    91
    Nov 13, 2002
    Epsom Downs, Surrey
    Your Mercedes:
    Ml320CDI 2007
    Excessive crankcase pressure caused by blocked breather, or maybe they have left something out or just reassembled it wrong...
  5. Uncle Benz
    Uncle Benz Senior Member
    2,287
    440
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    It wouldn't surprise me if the chain tensioner sealing washer was the culprit.
    Steve@Avantgarde likes this.
  6. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,604
    777
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    Mercedes-Benz C32AMG, SL55AMG, C320CDI Sport Edition Estate and SLR McLaren Coupe Roadster.
    Good shout, have seen this on OM651's quite a bit.
Share This Page
