On w 220 when easy entry is selected the steering wheel moves ok but seat does not
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by mercmancdi, Dec 4, 2018 at 8:06 PM.
  1. mercmancdi
    mercmancdi Senior Member
    1,926
    157
    Dec 6, 2011
    templepatrick - co antrim
    Your Mercedes:
    2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
    w220 when I select easy entry on the menu the steering wheel moves away find but seat does not move.
    While the option is there I assume the seat should slide back.
    Apart from a broken wire is there any common fault know for this.
  2. L John
    L John Senior Member
    2,798
    519
    Nov 24, 2013
    Your Mercedes:
    W204 C350 Petrol Elegance
    My W204 only moves the steering wheel for easy exit. I was expecting it to move the seat but it never has, do some models move the seat and others not?
  3. OP
    mercmancdi
    1,926
    157
    Dec 6, 2011
    Your Mercedes:
    Do you have the seat option come up on dash menu.
  4. L John
    2,798
    519
    Nov 24, 2013
    Your Mercedes:
    Only an easy entry/exit option, no mention of seats.
    Mine has the full memory pack with the 3 saves so I see no reason why it shouldn't do the seat but thought it was in case of rear passengers.
    At least with the memory option you need to keep your finger on the button until the position is reached, so a yell from behind would cause you to immediately let go of the button.
    If it was linked to the easy exit, it would do the full amount of auto travel, however far that may be and so possibly the seats are not active from a safety point of view.
  5. V6Matty
    V6Matty Senior Member
    5,362
    451
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    S212/10/E350(His) W169/2005/A180 (Hers)
    Same for my 212 with Multi contor seats, just the steering wheel that moves, very different to my pug where the seat moved but the steering wheel didn't
  6. Naraic
    Naraic Moderator
    9,886
    637
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    The W220 and W215 should move the seat.
    Actually, to be more accurate I can choose to turn the feature off (which I prefer) or have the steering column move only or the steering column and the seat.
    L John likes this.
  7. John Laidlaw
    John Laidlaw Senior Member
    17,148
    4,079
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    As Matt my 212 only moves the wheel, my 230 moved both
    Different strokes I’d say.....
  8. Naraic
    Naraic Moderator
    9,886
    637
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
  9. L John
    2,798
    519
    Nov 24, 2013
    Your Mercedes:
    The video is a 2006 or 2007 car, I wonder if they had complaints from rear seated passengers getting knees crushed and removed the easy entry/exit seat option on later cars, unless it's still an option on some Mercedes models?
  10. AMGeed
    AMGeed Senior Member
    4,791
    1,019
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
    2004 W211 E55K ///AMG
    If the seat is already set at full recline, it won't go back any further anyway.
    Also, possibly a broken wire in the n/s boot hinge area.
    Fitting a new GPS antenna earlier this year I had to strip out the hinge cover and found broken wires. After repairing them, my easy entry was working again. I hadn't even noticed it had stopped:p
  11. OP
    mercmancdi
    1,926
    157
    Dec 6, 2011
    Your Mercedes:
    That’s same menu as mine.
  12. OP
    mercmancdi
    1,926
    157
    Dec 6, 2011
    Your Mercedes:
    I had a clk and it seat didn’t move and star showed faulty wire , I removed the seat brought it in the house stripped back the wires and 2 were rubbed , repaired them and it worked a treat. Although seat might be harder to remove on a 4 door.
  13. AMGeed
    4,791
    1,019
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
    ^ Star is so useful finding faults.
    mercmancdi likes this.
  14. Srdl
    Srdl Senior Member
    1,307
    491
    Oct 8, 2015
    Hampshire
    Your Mercedes:
    GLC43 AMG 2018 (X253) Premium Plus
    On mine, only the steering wheel moves. I have just read the relevant part of the Manual and it only mentions the steering wheel, not the seats. I had assumed the seat didn’t move because I’ve got long legs and have it quite a long way back anyway.
  15. OP
    mercmancdi
    1,926
    157
    Dec 6, 2011
    Your Mercedes:
    Does the seat menu come up on your
    screen.
  16. OP
    mercmancdi
    1,926
    157
    Dec 6, 2011
    Your Mercedes:
    Ok got the icarsoft v2 I purchased and bingo cleared few faults and now the seat and steering action is both working. So far so good.
    Naraic likes this.
  17. John Laidlaw
    17,148
    4,079
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Happy days!
  18. Naraic
    Naraic Moderator
    9,886
    637
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Have you got a w220 too?
  19. Naraic
    Naraic Moderator
    9,886
    637
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Result Mr G!
  20. AMGeed
    4,791
    1,019
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
    Nice one Steve. Slowly but surely you are getting there.
Share This Page
