joderest
- Apr 16, 2018
- ML270 2003
Since buying my ML270, i have investigated and cured all its faults except for two, no one i have asked has any clue about these two faults, so thought i would try one last time before giving up, even Mercedes have no clue, and just want to swap parts until it goes away.
1) Windscreen air flap.
The Fault >>> Start car in the morning or what ever is first start of day, all the directional flaps will work except air to windscreen, drive car a mile down the road, stop engine, count to ten, re start car, select air to windscreen, after about a 5 second delay, flap will open. It will then work as it should unless car left again for 10 hours or more, then back to square one.
What has been done>>>> Air flap motor replaced, all wiring checked, flap motors all set up on STAR (worked for a week, then back to square one), battery replaced as showed low voltage, all flaps checked and working when moved by hand.
2) Parktronic>>> front left side, intermittently goes faulty, MB2 gave outside left sensor faulty, replaced sensor, still the same. Got under bumper and disconnected wiring block, cleaned and put back, all this did was move fault to next sensor, did it again, fault back on outside sensor. MB2 shows 5 front sensors at 255, outside left sensor at 63. tried replacing sensor again, same readings same fault. However, some days works perfectly.
I have no hair left now due to these last two issues, rest of car is now good. Does anyone have any ideas of what to check, do or what ever.
