The car would randomly go into limp home mode and not accelarate, no EML light would come on and the fault would disapear if you let it sit for 10 -15 mins. The other day however it decided to go to limp home and put on the EML light, got isoft 980 out and it had stored P0244 turbo waste gate.
So I have removed the acctuator and checked the rod still moves on the back of the turbo, I have ordered a replacement part from turbovanes in birmingham.
In looking into other forum reports the swirl flap drive seems to be linked with this fault also, do the collective think it would be ok to do a bypass modification on the swirl flap motor (using a properly modified plug, not just a resistor and tape) at the same time as replacing the acctuator?
