Penetrating fluid test.
Discussion in 'Motoring Related Discussion' started by Frontstep, Oct 6, 2018.
  1. Frontstep
    Frontstep Senior Member
    6,384
    448
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    A real corrosion nerd video testing various penetrants I will stick to atf and acetone for now.
  2. Craiglxviii
    Craiglxviii Senior Member
    13,350
    2,917
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    W215 CL500 Motorway Queen; W251 R320L Familybenz, S211 E320 Avg Designo Edition now sadly missed.
    Now that IS interesting...
    Shame he didn’t have any Plus Gas!
  3. om613
    om613 Senior Member
    1,304
    242
    Aug 29, 2015
    london
    Your Mercedes:
    S202 C250TD, S123 240TD
    No. I can't listen to him any longer (at 20 seconds).
  4. davidsl500
    davidsl500 Senior Member
    1,430
    83
    Oct 24, 2004
    Your Mercedes:
    R129 SL500 - GONE!!, X Type 2.2D SE
    I would have liked to have seen heat in the comparisons and .... coke!
  5. John Laidlaw
    John Laidlaw Senior Member
    17,664
    4,319
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
  6. PaulG
    PaulG Senior Member
    779
    91
    Nov 13, 2002
    Epsom Downs, Surrey
    Your Mercedes:
    Ml320CDI 2007
    My experience with penetrating oils is that NONE of them get to where they need to go. Using perspex to demonstration purposes is all very well, but it doesn't emulate actual conditions where both nut and bolt will be rusting.
    If a bolt is rusted solid such that you need to get brutal with it, the penetration oil won''t be able to get in there.
    Obviously, once the bolt has moved initially any kind of thin oil will work, but that's not the marketing thrust that Penetrating oils are sold on.
    All the above IMHO, obviously, but I've been spannering cars for nearly 50 years and this is the conclusion I've come to.
    Westheath and om613 like this.
  7. daveenty
    daveenty Senior Member
    2,749
    748
    Jun 21, 2005
    The Frozen North :(
    Your Mercedes:
    2017 W213 E63s & 1989 W201 2.5-16
    Agree with all of the above.
    If it won't undo then either a substantial amount of heat to persuade it, or an angle grinder to eliminate it. Drastic the secondary approach may be, but it's certainly time saving in the grand scale of things.
  8. OP
    Frontstep
    6,384
    448
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    Heat is when possible the best thing I have used, some penetrating fluids given long enough do make a difference.
    A clout with the hammer can sometimes improve things.
    What riles me is why some manufacturers still churn out rust magnets for safety critical components.
  9. barnaclebill15
    barnaclebill15 Senior Member
    193
    29
    Mar 24, 2015
    newcastle upon tyne
    Your Mercedes:
    clk220cdi/2006/diesel
    Worst removal I had was in 1968 working in a power station, two of us got the job of changing 16 1" BSF studs in a steam valve of a main boiler. Another power station had the same valve cover blow off when the studs failed.
    First we tried locking two nuts to unscrew using lots of penetrating oil, then we welded the nuts on the studs, then we cut the studs to just over 1" high and welded nuts on still no movement, finally we drilled 1/2" holes down each stud and filled them with welding hoping they would contract, they did but it still took a 16lb sledge hammer on a flogging ring all the way out, sure that the penetrating oil did nothing.
    Westheath likes this.
  10. mercmancdi
    mercmancdi Senior Member
    2,042
    192
    Dec 6, 2011
    templepatrick - co antrim
    Your Mercedes:
    2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
    Agree the secret is in getting the first movement then being sensible with little oil working it in back and forth.
    Frontstep likes this.
  11. mercmancdi
    2,042
    192
    Dec 6, 2011
    Your Mercedes:
    Do you s think impact wrench’s make life easier . As long as you don’t round the head
  12. LostKiwi
    LostKiwi Senior Member
    15,067
    6,110
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Yes.
    Less chance of rounding the head of you use the correct impact socket (which will be a 6 point hex as opposed to the more usual 12 point). Biggest danger with impact wrenches is snapping the bolt/stud.
    mercmancdi likes this.
  13. Xtractorfan
    Xtractorfan Senior Member
    6,074
    143
    Nov 16, 2007
    Your Mercedes:
    S class
  14. Westheath
    Westheath Senior Member
    1,440
    449
    Nov 6, 2015
    South London
    Your Mercedes:
    Coke/Pepsi is a myth but try telling those that have used it and believe it works lol.
    Diesel, atf, light oils, heat cold, every squirty can brand under the sun promising freedom and release of the rusty stuff ........ sacrificing a chicken ....... been there got the T-shirt.
    If it not coming out/undone its not coming out............
    Drilling the bastige is my preferred method, but then this starts the discussion Colbalt Carbide Tungsten, even the little drill set once found in a Xmas cracker..........
  15. davidsl500
    1,430
    83
    Oct 24, 2004
    Your Mercedes:
    Cola contains phosphoric acid - it gives it its acidic taste / tartness. Have a look at the Wiki article on Phosphate conversion coatings https://en.wikipedia.org/wiki/Phosphate_conversion_coating
    So its not all myth...
  16. Xtractorfan
    6,074
    143
    Nov 16, 2007
    Your Mercedes:
    S class
    A few mechanics have told me they use coke overnite on black death and then run the engine until it gets hot and the black death just scrapes off like toffee
  17. Westheath
    1,440
    449
    Nov 6, 2015
    South London
    Your Mercedes:
    Run the engine till its hot and it scrapes off anyway.
    Not doing the Coke debate, been doing this sh*t too long to know what works and don't,
    if someone thinks it worked then they couldn't have been trying hard enough the first time. imho
  18. OP
    Frontstep
    6,384
    448
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    Used Mr Muscle for black death on a warm engine worked for me oh and some carb cleaner finished it off nicely.
    Lots of people use same stuff.
    There are some more noxious chemicals that work well but they are not commonly available.
  19. davidsl500
    1,430
    83
    Oct 24, 2004
    Your Mercedes:
    That's a cop out... is the earth flat in your world? ;)
  20. Westheath
    1,440
    449
    Nov 6, 2015
    South London
    Your Mercedes:
    Not a cop out just some common sense.
    A 12 oz. can of cola with caffeine contains the most with 37 mg of phosphorus,
    while the same size serving of diet cola with caffeine contains 32 mg.
    Cream soda, ginger ale and root beer are all phosphorus free.
    Milk and yogurt contain more phosphorus than soft drinks.
    An 8 oz. serving of skim milk has 247 mg, and an 8 oz. serving of yogurt 385 mg.
    https://www.livestrong.com/article/504049-the-phosphate-levels-of-soft-drinks/
    I don't see any one pouring milk over their rusty nuts and bolts
    or putting yogurt on seized injectors.
Share This Page
