Hello All
I have a '96 C280 which has been faultless all its life. At 140,000 miles now and still uses hardly any oil at all.
It has always started first turn of the key but it has gradually got worse and worse. It will fire but I have to let it churn away for a while. Cold or hot same problem. However it will sometimes start first time!
My question is what components/sensors are likely to cause this. Could it be that I simply need new plugs or should I be looking at a particular sensor? There are no warning lights on the dash, so I'm guessing there are no codes to check for diagnosis?
Any suggestions appreciated.
Max
Max
