Question on retrofitting Bonnet Gas Struts
ZZZZ
I quite fancy fitting a pair of gas struts, to lift the bonnet on my C169, instead of the factory swing-up fixed strut, which feels positively ancient and uncouth :rolleyes:
Anyone done this mod? Any pointers?
I've seen a picture of W245 with retrofitted gas struts, sometime ago, so it's definitely possible :)
Can't advise on wether it's possible buddy , but I bourght some replacements from a uk engineering company called SGS who make jacks as well as struts .
00slk
Cambridgeshire UK
Now this rings a bell.......A few years ago I heard of someone fitting a gas strut instead of the pole support. It didn't work quite the way they planned it and it put a twist on the bonnet when they closed it. It was resolved by fitting a pair equally on both sides.
Don't go for a too stronger strut though, pushing them closed with all your might and your chin leaning over the bonnet can result in much pain when your fingers slip off the front edge of the bonnet. :(
And I'm not talking from experience either, saw it happen, still think it was funny..................
You need to carefully calculate angles and loads. You need to be able to open the bonnet the right amount but also gecable to close it. Strut length and travel obviously plays a big part but so does the location of each end. You also need to have it set so there is minimal force when the bonnet is on the safety latch.
Finally the mountings at each end will need to withstand quite a lot of force without distorting the panels and mounts.
I did all this years ago on a Defender rear door and it wasn't an easy exercise.
Z
ZZZZ
Thanks chaps. Sounds a bit more involved, than I hoped for.
The W169 bonnet is surprisingly heavy for such a small car, so that might be a problem getting the balance right.
Also, the bonnet is not meant to be closed by pushing it down, but rather just dropping it from about 10 inches ... that might not go well with gas struts, if they are too strong.
Perhaps my modification desire is better channeled somewhere else in the car :)
Try and talk someone else into trying it first , just in case :D
Z
ZZZZ
That might be a tad challenging - most W169 owners wouldn't entertain the idea of doing anything, but the bare minimum to maintain the car, let alone spending money, and effort, on modifying it o_O
I'm on my own in my insanity here :alien:
area51
Kent
Year2000 A160
If you haven't already done so,maybe have look at Elchfans? I know that this has been done to W168s, perhaps there is a kit available.
Z
ZZZZ
Right, excellent idea - I forgot about that one - thanks.
forrera
several W168, W169 and W245s
I think there's a good reason A and B class bonnets don't have gas struts. You're meant to slam the bonnet to shut it and if it doesn't shut, because of the struts, you'll be tempted to push it down with your hand heel and cause these nasty dents by the star.
This one was done by Kwik fit.
Z
ZZZZ
Yes, I've seen even a main dealer tech pushing it down, rather than dropping the bonnet to shut ...
EmilysDad
Bury Lancs
ML350
IMHO it's just a cost thing. A bent 5mm bar is much cheaper than a pair of gas struts ... if there was a will, they'd have been fitted. The front bonnet/boot lid of a Smart Roadster has a pair of gas struts & the bonnet/boot lid is plastic.
