No problem. I'm doing a front end rebuild on mine at the moment tooThanks for your input LostKiwi
For damper struts there's Sachs, Bilstein and then MB themselves. For my 1992 500SLs Sachs damper struts were about £110 a corner, Bilstein £135 and MB £260. I suspect Bilstein are the OEM for MB.
I chose Bilstein B4s based on reports from others about handling.
Damper strut top mounts can be had from Febi Bilstein for £50 each on eBay or from MB for £75ish. I went with MB.
Springs I suspect should be MB only - as LostKiwi says there are many combinations based on a weight calculation.
But having come this far, why wouldn't you replace the Lower Control Arms? You get the bushings and the ball joint done that way, and the marginal cost of the labour (or your time) to do this job is small, since the springs are out anyway. Lemforder are £150 a side for my car, other makes run cheaper but will probably fail more quickly.
Then there's the steering damper, steering idler arm bushing, maybe engine mounts, transmission mount. Then time for a proper alignment from someone who knows their stuff, unless you want to start on the rear suspension first? After all, having dropped £1000-£1200 on parts for the front it would be a shame not to get the full benefit....
