R129 under bonnet insulation
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by chardF, Jan 12, 2017.
  1. chardF
    chardF Senior Member
    370
    Aug 25, 2013
    Warwickshire
    Your Mercedes:
    SL 1994 320 R129
    Hi all
    Mine has given up the ghost, crumbled and collapsed. Tired of having bit's drop on me when I'm checking the oil or whatever, I've pulled the rementents off. It came off pretty easily actually, just a couple of bit's left to scrape, a job for when the weather gets a little warmer.
    Has anyone tried the SL shop version?
    http://www.theslshop.com/mercedes-benz-sl-r-129-under-bonnet-insulation-1296802025.html
    I can't imagine this item is much more from an MB dealer?
    Any other suppliers or generic solutions used? I'm guessing it'll provide heat and noise insulation, mine is only a 320 so under bonnet temperatures never get all that high, does leaving it off make much difference?
  2. brick10
    brick10 Senior Member
    885
    5
    Sep 19, 2011
    Ely Camb.
    Your Mercedes:
    CLK 280 AMG
    That looks quite good to me, i replaced mine a few years ago, got it off e-bay for about £80, but that looks better.
  3. DREAMER NO2
    DREAMER NO2 Senior Member
    1,461
    8
    Dec 29, 2013
    Your Mercedes:
    W124 2.6E M103
    Just remember to use the Mercedes Glue to fix the new one on to the bonnet Or ask other members what they have used.
  4. brick10
    885
    5
    Sep 19, 2011
    Ely Camb.
    Your Mercedes:
    CLK 280 AMG
    It's a cr*p job anyway, but worthwhile, and has to be done.
  5. LostKiwi
    LostKiwi Senior Member
    4,023
    299
    Aug 25, 2006
    Midlands, not east or west but middle.
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 04 Smart Roadster Coupe
    That looks the same as mine. If so it looks good and nicely made too.
  6. pancholi
    pancholi Senior Member
    373
    Sep 25, 2004
    Your Mercedes:
    1996 SL 500 , 2003 CL55K, 2005 E55K
  7. worldbiker
    worldbiker Senior Member
    55
    Apr 13, 2014
    London
    Your Mercedes:
    1996 SL320
    Very easy. Good bit of kit from the SL shop. I did it - this is what I posted back in May 2015
    "Not a 280SL but an 320SL (sorry). I bought a new insulation pad from the SL Store, together with replacement clips and spray on adhesive.
    The old one came off pretty easily (spread an old sheet over the engine to collect the debris) and then used a stiff broom and blunt paint scraper to clean off as much as possible of the old glue and residue.
    Sprayed the bonnet and new pad with adhesive, left it to become tacky, then hung it on the new clips at the front of the bonnet and then smoothed it down (like hanging wallpaper). All good and seems to be stuck like sh*t to the proverbial blanket.
    The only PIA was removing the old clips, which was what I expected and why I bought new ones.
    Hope that helps."
  8. OP
    chardF
    370
    Aug 25, 2013
    Warwickshire
    Your Mercedes:
    SL 1994 320 R129
  9. OP
    chardF
    370
    Aug 25, 2013
    Warwickshire
    Your Mercedes:
    SL 1994 320 R129
    Another question, is 1 x 500ml aerosol of trim adhesive enough?
  10. pancholi
    373
    Sep 25, 2004
    Your Mercedes:
    sorry i have not got round to sorting mine out yet. as my CL 55K is a demanding Queen, so money gets thrown on her first :(
    raj
  11. pancholi
    373
    Sep 25, 2004
    Your Mercedes:
  12. OP
    chardF
    370
    Aug 25, 2013
    Warwickshire
    Your Mercedes:
    SL 1994 320 R129
    Thanks, love that video, fat dad on a bendy bridge.:)
    I think I'll order one and give it a go. My pad collapsed so I removed it, I think I'm noticing more engine noise now!
    I'm thinking of a different technique. Dangle the pad from the bonnet using the press rivets, spray with adhesive, raise to vertical position then smooth down.
  13. LostKiwi
    4,023
    299
    Aug 25, 2006
    Your Mercedes:
    From when I had Range Rovers and had to glue the headlining back in I was never particularly impressed with spray adhesive as I found it didn't last long before it started sagging again.
    I'd be more inclined to use a brush on product.
  14. pancholi
    373
    Sep 25, 2004
    Your Mercedes:
    any products you recommend?
  15. LostKiwi
    4,023
    299
    Aug 25, 2006
    Your Mercedes:
    I seem to recall using EvoStik Impact. It was some time back mind!
  16. OP
    chardF
    370
    Aug 25, 2013
    Warwickshire
    Your Mercedes:
    SL 1994 320 R129
  17. LostKiwi
    4,023
    299
    Aug 25, 2006
    Your Mercedes:
  18. OP
    chardF
    370
    Aug 25, 2013
    Warwickshire
    Your Mercedes:
    SL 1994 320 R129
  19. OP
    chardF
    370
    Aug 25, 2013
    Warwickshire
    Your Mercedes:
    SL 1994 320 R129
    So stripped off old insulation and left with this.
    Combination of scraper, drill and dremel with polishing pads left this.
    Dangle pad from push rivets, spray with adhesive (500ml was about right)
    Wait 10mins and smooth down.
    Sorry about the rubbish photos, important to work quickly before Mrs F discovers where her curtains are. :p
  20. pancholi
    373
    Sep 25, 2004
    Your Mercedes:
    thanks for the pics and info..
    where did you get the insulation pad from?
    quality good?
    cheers raj
    sorry just read the previous thread : you got it from Germany... all ok re. delivery and quality?
Share This Page
