R230 Consumer Battery
Discussion in 'General Mercedes-Benz Related Discussion' started by nicholas15, Jan 11, 2019.
  1. nicholas15
    nicholas15 Senior Member
    456
    95
    Dec 1, 2015
    near Ashford, Kent
    Your Mercedes:
    s class w221 - 2012 350 Bluetec, SL500 r230 2003
    Following advise here, I having invested in a CTEK charger for use on 2003 SL500.
    My question now, is can I charge the consumer battery via the cigarette lighter or only via the terminals on the battery in the boot?
    I presume it is an AGM battery?
  2. ajlsl600
    ajlsl600 Senior Member
    1,900
    405
    Nov 18, 2013
    france
    Your Mercedes:
    clk3202001,sl6002003 with everything,A class 170cdi auto
    i just connected up the plug end cables to the batt and leave the lead poking out into the boot,i find that once conected its still no issue to close the boot. agm it tis. i also keep a ctek on the front batt ,tho i rotate that on SL,CLK dont know about fag lighter as input, someone surely will, seems best to me to involve going thru as little as possible to charge consumer batt .rules out ANY dramas
    nicholas15 likes this.
  3. LostKiwi
    LostKiwi Senior Member
    14,995
    6,068
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Only via the battery terminals.
    Easiest way is to put a fixed fly lead on the battery and use that to connect the battery. The CTEK usually comes with a flylead with eyelets that will do the job. Yes it's an AGM battery.
  4. McDonald
    McDonald Senior Member
    593
    390
    Apr 11, 2017
    Surrey
    Your Mercedes:
    SL500 2004
    While my car is resting I use a Ctec battery conditioner on the consumer battery, but not on the starter battery. Am I just lucky that the car starts immediately every time?
  5. LostKiwi
    14,995
    6,068
    Aug 25, 2006
    Your Mercedes:
    Never had to charge the starter battery on ours. The consumer battery goes flat for fun though....
    Blobcat and nicholas15 like this.
  6. ajlsl600
    1,900
    405
    Nov 18, 2013
    france
    Your Mercedes:
    my start batt went dead a few yr ago, it was 10. since no issue i just prefer to rotate the ctek now and then. mine spends 4 /5 months in its cot.
  7. Denis O
    Denis O Senior Member
    61
    28
    Jan 29, 2004
    Weald of Kent
    I have a fly lead attached to both starter and consumer batteries in my 350. Most of the time the C-Tek is on the consumer but every now and again I give the starter battery a quick shot. It certainly won't do it any harm even if it doesn't need it.
  8. OP
    nicholas15
    456
    95
    Dec 1, 2015
    near Ashford, Kent
    Your Mercedes:
    Thanks. The consumer battery has eyelets attached from the previous owner so will use those.Thought I ought to do something because I will be in New Zealand over next couple of months
    Also thanks to others for their comments.
  9. LostKiwi
    14,995
    6,068
    Aug 25, 2006
    Your Mercedes:
    Excellent! Which part of the country are you going to?
  10. OP
    nicholas15
    456
    95
    Dec 1, 2015
    near Ashford, Kent
    Your Mercedes:
    Typical tourist; fly into Auckland, hire a car, then Paihai, Stratford, (Forgotten Highway), Cambridge, Rotorua, Wellington, then bus for South Island, Christchurch, Trans Alpine, Fran Josef, Queenstown, Christchurch, Auckland
    Guess much of that is familiar to you!
  11. 00slk
    00slk Senior Member
    2,396
    805
    Dec 1, 2012
    Cambridgeshire UK
    Your Mercedes:
    2002 SL55 AMG, 2003 SL500
    Yep, been to all those places ;)
    We just leave our car batteries connected when we go overseas, longest time left was 3 months and haven't had any flat battery issues. Hope I haven't said anything, I don't want any bad omens :eek:
  12. LostKiwi
    14,995
    6,068
    Aug 25, 2006
    Your Mercedes:
Share This Page
