r230 pse pump coding
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Doc47, Aug 9, 2018.
  1. Doc47
    Doc47 Member
    11
    Dec 14, 2017
    Your Mercedes:
    SL 2012 300
    I am buying a new PSE vacuum pump but have read on this forum that it will need to be coded to the car. How is this done, does it need to be done by a MB dealer or can my local garage do it.
  2. John Laidlaw
    John Laidlaw Senior Member
    17,170
    4,085
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    If your local garage has STAR then he could do it
  3. OP
    Doc47
    Doc47 Member
    11
    Dec 14, 2017
    Your Mercedes:
    SL 2012 300
    Thank you John.
  4. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,461
    693
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    Mercedes-Benz C32AMG, SL55AMG, C320CDI Sport Edition Estate and SLR McLaren Coupe Roadster.
    Im pretty sure they are plug and play. It may need to be told some variant coding for country specific items, but it should fire up as soon as its connected and working.
  5. mersum1es
    mersum1es Senior Member
    1,646
    67
    Sep 25, 2010
    Finland
    Your Mercedes:
    W219/-07/320CDI, W220/-01/320CDI, EX:W211/-04/320CDI, EX:W210/-01/270CDI
    W220 PSE pump is not p'n'p... but it is because so many different options, not sure how much variations W230 has
  6. Steve@Avantgarde
    6,461
    693
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    I've fitted 3 PSE pumps to SL's in the last month and every one of them fired up the CL and roof the moment they were plugged in.
  7. mersum1es
    1,646
    67
    Sep 25, 2010
    Finland
    Your Mercedes:
    ok, CL may have more 'standardized' options, good that at least something is easy... :)
  8. star
    star Forum Supporter Authorised Forum Supporter
    4,785
    272
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    I think you have to program lumber support, everything else will work.
  9. OP
    Doc47
    Doc47 Member
    11
    Dec 14, 2017
    Your Mercedes:
    SL 2012 300
    Thanks everyone.
  10. Submariner1
    Submariner1 Senior Member
    4,329
    569
    Sep 3, 2016
    Windsor Berkshire
    Your Mercedes:
    CL500 2009 5.5
    As Star said there is a guy in the US, who couldnt get Lumbar pads to pump up. OK on an S Class so might not be relevant.
    Finally bought a new pump, and it still wouldnt work the Lumbar supports. He found it needed Star to configure the pump. He said they found it saying “not present” they changed it to “present” and it all worked perfectly.
  11. OP
    Doc47
    Doc47 Member
    11
    Dec 14, 2017
    Your Mercedes:
    SL 2012 300
    Just for feedback, I fitted a new PSE pump and everything worked p,n,p, except for the lumbar support which star and submariner indicated was correct, I will live without the lumbar support until I get it serviced again.
    Thanks for all your help.
    p.s. anyone want to buy a used PSE pump cheap.
Share This Page
