00slk
- Dec 1, 2012
- Location
- Cambridgeshire UK
- 2002 SL55 AMG, 2005 E320 CDi, 2014 SLK250 CDi, 2003 SLK200
...As the pictures shows, stuck in this position
Works fine until the load cover has been retracted and brought forward and clipped back into place, then the roof stays in this position. After 15 minutes works again fine until load cover is moved.
Code indicated a past flat battery for longer than .8 seconds, once the code was cleared everything seems to work fine.
The electrician seems to think it could have been the fault memory causing the problem
Suspect a faulty micro switch?? Or now fixed?
While he was here I got him to fix the power socket for the 12v charger in the ash tray on the 55 as it stopped working 9 months ago, all fixed
