Race Chip?
Mark 2657
AMG C43 Cabrio
HI, I've had a 2016 C43 for just over 2 years and the only thing letting it down is I could do with a bit more HP.
Has anyone fitted a Racechip to their C43?
For £600 and a claimed 67 extra HP and 123 Nm it sounds pretty good value.
Any comments woud be appreciated.
Cheers, Mark.
JBell
Torquey
C350 CDi Estate (GAD Edition)
Where are you based???
I would take it to GAD or MSL, well known on here for tuning C63
As above. I'd rather use someone who knows the C63 engine inside out and MSL certainly have some experience.
John Laidlaw
Wirral
Land Rover Discovery 4
Can only agree with the above. MSL won’t charge too much more for a remap & dyno session and you know if it can be done, they will do it reliably
JBell
Torquey
£700 for map with before and after dyno runs on offer at the moment
M
Mark 2657
AMG C43 Cabrio
It's a C43 but I daresay if they can sort the 63 they should be OK.
I am in Co Durham so Birmingham isn't a place I ever get to.
I used to take the Subarus to Revolution in Gateshead and was thinking about a rolling road test before and after fitting the race chip.
As the car is still under warranty I quite liked the idea of unplugging it for the next service.
Thanks for the input so far.
Mark.
bembo449
gainsborough , lincolnshire
well my 2p's worth , a mate has an 18 reg A45 AMG , recently fitted a tricolore box for the same reason as you ( removability ) the car wasn't happy at all , yes it was faster etc but the rev gauge bounced between gear changes when driven harder , took it off again and the car was fine
John Laidlaw
Wirral
the OP says its for a C43 not C63 chaps :geek:
Yip knew that, that’s why I said MSL ‘should’, I’m not sure if they’ve done a 43 before but I’m guessing so.
3.0 twin turbo should work
John Laidlaw
Wirral
Mark.
If MSL do it they can remap the ECU with very little chance of being detected by MB during service. They’d have to interrogate the ECU specifically to find it. Even if they overwrite by accident it can be reinstated after as MSL keep the file
M
Mark 2657
AMG C43 Cabrio
  • #17
Stokesly, Looks good to me.
Will give him a call after hols.
Thanks all, Mark.
JBell
Torquey
GAD North then http://gadtuningnorthltd.co.uk/
The map will be undetectable by a dealer
Headhurts
Norwich, Norfolk
Mercedes GLC300 2021
It amuses me that the C43 does not have enough power for you but then again my E350 can frighten me, that said there is plenty of good advice here so I wish you well in your search for more speed.
Robin
bembo449
its not ALL about power , its about drivability / flexibility and more usable grunt in the rev range where it really matters , remaps do soooo much more than up the BHP
