Re-Map
Discussion in 'Tuning, Styling and Performance.' started by Billy Bowden, Sep 7, 2018.
  1. Billy Bowden
    Billy Bowden Member
    13
    17
    Aug 11, 2018
    Your Mercedes:
    2014 E220 CDI amg
    Hi all I'm thinking of having a remap done on my E220 W212 amg line 2014 has anybody used GAD tuning ? After speaking with them they are offering an extra 67bhp and 100 torgue . Any opinions greatfully received thanks
  2. thebiglad
    thebiglad Senior Member
    301
    147
    Aug 15, 2018
    Central France
    Your Mercedes:
    2005 CLK 270 cdi
    That seems to be about a 45% increase in power and torque. I know that most owners don't use this new-found power all the time, but I would be concerned about such a radical increase and it's effects on the engine components.
  3. OP
    Billy Bowden
    Billy Bowden Member
    13
    17
    Aug 11, 2018
    Your Mercedes:
    2014 E220 CDI amg
    Sorry it's 57 bhp increase I mentioned the gearbox no being able to take the added torque he assured me in saying the gearbox is set at 550 torque and he will be only upping it to 500 torque ive never had a remap before so i am apprehensive.....
  4. thebiglad
    301
    147
    Aug 15, 2018
    Central France
    Your Mercedes:
    2005 CLK 270 cdi
    I'm less concerned about the 'box and more concerned about the engine to be honest and I'll give you a small example of why I'm worried on your behalf.
    This example is not Mercedes but Land Rover TD5 - 5 cylinder Turbo diesel. Back in the day many peeps were wanting a big more go than the std. 136 bhp and so went down the remap route pushing the power to on average 165-170 bhp. And they drove much better - for a while.
    Then a number of owners began to report a strange whistling noise coming from the engine on acceleration. It was diagnosed to be a leak of exhaust gases coming from the interface between the head and the exhaust manifold. Further research found that the manifold had warped, often taking 2 exhaust studs with it.
    More clever people than I began investigating this and found the problem. They measured the std engine exhaust gas temps and compared them with the remapped cars EGT's and found that the remapped engine had EGT's significantly higher (can't remember the exact % but something like 25% higher) than the std. engine. They concluded that whilst not every engine was affected (probably due to driver differences,) a large proportion of remapped cars needed to have their exhaust manifold planed flat and installed with stronger studs and nuts.
    So whilst the example above does not relate to your car directly, it does cast doubt on the remappers claims of "no problems" for your engine.
    But it's up to you to choose..........................
    These days I go for greater efficiency rather than re-mapping, so I use the most 'low drag' transmission oils & tyres, always have tyre pressures correct, don't carry unnecessary weight, over-service car with new air filters every other minute and cleaned MAF and MAP sensors. Optimising my vehicles, in short.
    Billy Bowden likes this.
  5. Craiglxviii
    Craiglxviii Senior Member
    13,350
    2,917
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    W215 CL500 Motorway Queen; W251 R320L Familybenz, S211 E320 Avg Designo Edition now sadly missed.
    The 220 engine is the same as the 250 with mapping and turbo differences only. So it isn't unfeasible to expect it to achieve around 250 levels on a remap (177bhp ==> 204bhp). 57bhp increase would take the engine to 234bhp. Now, knowing MB engines I'd not be overly worried about the engine handling it...
    The transmission is already accepting 440Nm from a stock 220 setup, adding 100Nm takes it to 320/350 territory.
    I'm not sure what the 7G-Tronic transmission on the 220 is set up to handle, one of our indies might like to comment.
    GAD have been used by a number of forum members, comments seem favourable. NB they do not have a rolling road so maps are generic and not tuned to your specific car.
  6. JBell
    JBell Senior Member
    9,241
    1,640
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    Need to correct you on this Craig:
    All their maps are bespoke to the car, each one is mapped individually after interrogating the car's ECU. I watched Anthony do mine, took over an hour to get it all correct.
    They do have a Rolling Road by "Dyno Developments"
    bembo449 likes this.
  7. OP
    Billy Bowden
    Billy Bowden Member
    13
    17
    Aug 11, 2018
    Your Mercedes:
    2014 E220 CDI amg
    Hi Craig they actually don't have a rolling road
    Hi Craig the 220 gearbox is set up to take 550 torque standard according to Naz at GAD northwest also he does not have rolling road but does have use of one at cost price.....thanks for posting
  8. Craiglxviii
    13,350
    2,917
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    Ah thanks Jon. My mistake- that’s good to know.
  9. bembo449
    bembo449 Senior Member
    2,666
    475
    Jan 2, 2012
    lincolnshire
    Your Mercedes:
    216 5.5 v8 , range rover vogue , 221 320cdi , alfa romeo brera
    im somewhat of a veteran where remaps are concerned , getting on towards 40 cars so far , never had a gearbox failure , well never had any issues at all bar my old 159jtd eating its clutch after 13k with a map on but that clutch was already 70k old at the time so not unexpected really , you need to remember that it will still feed the power in like the original map so not like an assault on the engine / transmission everytime you go near the throttle pedal pal
  10. JBell
    JBell Senior Member
    9,241
    1,640
    Dec 9, 2011
    Torquey
    Your Mercedes:
    Capra and bembo449 like this.
  11. Capra
    Capra Senior Member
    1,926
    413
    Jan 27, 2018
    Gloucestershire
    Your Mercedes:
    W204 2013 C350 CDI Pan roof
    Billy Bowden and JBell like this.
  12. Andyn666
    Andyn666 Senior Member
    65
    Aug 11, 2017
    Your Mercedes:
    2003 W211 E320 CDI estate
    I've had my 2003 w211 E320 CDI remapped to 297hp and 604Nm on a Dyno, with no hardware changes. Like most people I don't use the extra power all that often. I haven't had any problems with the engine or gearbox, or anything else, the car has now done 119000miles and was remapped at 107000.
    As far as I'm concerned as long as it's remapped by someone who knows what there doing and the car has been serviced properly then you'll be fine.
    Billy Bowden, bembo449 and Capra like this.
  13. OP
    Billy Bowden
    Billy Bowden Member
    13
    17
    Aug 11, 2018
    Your Mercedes:
    2014 E220 CDI amg
    I've decided after much research lots of phone calls to Naz at GAD TUNING to go ahead and have my car remapped.....I've spoken to **** technicians at Mercedes dealers and really fantastic ones ....spoken to my Mercedes specialist garage.....and even brabus ( which for nearly two grand offered less than what im getting ) for £400 from GAD i am going with the northwest guy whos in Newcastle upon tyne ( if your wondering brabus offered a chip only with increased fuel and increased turbo boost ) naz at GAD is offering 45 to 55 modifications to my original ecu map with a copy of my original map coz i got all anal about....what if something goes wrong lol.....so 220 bhp and 500 tourque.....from 167 bhp and 400 tourque standard....ive learnt the 250 engine and the 220 is not the same engine brabus and main dealer confirmed this.....ive tried to give as much information as i can to share with anybody interested here....remap in 2/3 weeks with an update and regular update to follow......thanks to all you guys for posting much appreciated thanks again
    Andyn666, bembo449 and Wighty like this.
  14. mercmancdi
    mercmancdi Senior Member
    2,042
    192
    Dec 6, 2011
    templepatrick - co antrim
    Your Mercedes:
    2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
    All I can say it’s good you done your home work and got a reptulal place to get it done ,, about 8 yrs ago I got a 2.5 Touareg dome and the guy pushed me to max out , 6 weeks later going over mountain Rd it broke the cam shaft , after getting it checked out I was informed it was 90% the remap.
    So wish I had done the research first , it was a costly experience.
  15. keefysher
    keefysher Senior Member
    2,474
    763
    May 4, 2007
    Hampshire
    Your Mercedes:
    W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
    Is Newcastle upon tyne in the northwest?? :confused::confused:
  16. thebiglad
    301
    147
    Aug 15, 2018
    Central France
    Your Mercedes:
    2005 CLK 270 cdi
    North east coast, next to Sunderland.
  17. OP
    Billy Bowden
    Billy Bowden Member
    13
    17
    Aug 11, 2018
    Your Mercedes:
    2014 E220 CDI amg
    It's north west of Sussex lol
    Wighty and thebiglad like this.
  18. OP
    Billy Bowden
    Billy Bowden Member
    13
    17
    Aug 11, 2018
    Your Mercedes:
    2014 E220 CDI amg
    Thanks for the assurances it's booked in with Naz at GAD for Monday coming
    Andyn666 likes this.
  19. bembo449
    2,666
    475
    Jan 2, 2012
    lincolnshire
    Your Mercedes:
    you will love it Billy :D:D:D
  20. OP
    Billy Bowden
    Billy Bowden Member
    13
    17
    Aug 11, 2018
    Your Mercedes:
    2014 E220 CDI amg
    Well I can now report Naz at GAD has remapped my car and she flies . I couldn't be happier lol
    St10pen, Bubble, JBell and 2 others like this.
Share This Page
