Recomended diagnostic testers please.
Discussion in 'Mercedes Goods on eBay' started by NicholasB, Dec 3, 2017.
  1. NicholasB
    NicholasB Active Member
    36
    Nov 9, 2009
    Wales UK
    Your Mercedes:
    C180 2008 Petrol Kompressor
    Any current recomendations please for a value for money diagnostic tester. (I'm in the UK)
    And of course any to avoid.
  2. LostKiwi
    LostKiwi Senior Member
    13,774
    5,201
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Depending how involved you want to get...
    iCarsoft i980
    iCarsoft MB-II
    STAR clone from China.
    There's an autel one and also Delphi and for your phone Carly.
  3. BeeJay
    BeeJay Senior Member
    441
    57
    May 13, 2007
    Powys, Mid-Wales
    Your Mercedes:
    SL 350 (2008) and Lexus LS 430 (2003)
    I have just bought a Foxwell NT624 Click Here
    The need to buy it was because of a problem with my daughter's Suzuki Swift. I primarily bought it because the power steering will intermittently show a fault, and become very heavy for her. This scanner was highly recommended on forums that I read, and allowed me to clear the faults with the Steering Angle Sensors, restoring the power steering. It worked first time, and was very easy to use. The first time the problem occurred we took it to a Suzuki dealer, and ended up paying £600 for diagnostics, leading to fitting of a reconditioned steering column and power steering unit.
    I also cleared a fault on my Lexus (which is a long story).
    Thus far I have not needed it for my SL or my wife's B-Class - perhaps I should not have said that in case they are listening ;)
    This particular scanner can be used with 50+ makes of cars, including Mercedes. It comes with 18 months of updates, allowing you to add new models and makes. Many forums suggest that the updates are actually free for life.
    There was something I did not fully understand when I received the scanner, I emailed the seller in China and got a good reply within hours.
    Perhaps there is someone on this forum who has used this brand of scanner with their Mercedes?
    The price is about £200- £250 in the UK, although I bought mine from China for £150 (incl delivery) with £20 of duty payable.
  4. Richard Moakes
    Richard Moakes Senior Member
    1,635
    May 19, 2002
    Newton Abbot, Devon, UK
    Your Mercedes:
    1991 R129.066 M119.960; 2005 W164.175 M113
    I have also had good success on W164 and W211 with the Carecar AET-1
    LostKiwi likes this.
  5. BeeJay
    441
    57
    May 13, 2007
    Powys, Mid-Wales
    Your Mercedes:
    A fundamental decision is whether you just want to read and clear faults, or make minor changes. A trivial example would be resetting the service indicator.
    Before purchasing mine I contacted a company in Swansea, asking whether one of the models they sold would do the job with the Suzuki (see above). They advised me that my initial choice would only read and clear faults, and directed me to the Foxwell NT624.
  6. Droverunner
    Droverunner Senior Member
    350
    118
    Aug 2, 2017
    West Cambridgeshire
    Your Mercedes:
    2007 CLK 220 CDI Sport AMG pack.
    For our Mercedes after looking around and taking advice here I bought the iCarsoft i980, paying about £85 on an offer. It has proved perfect for advanced DIY use and I was surprised just how much info and how many logged historic faults it picked up as our car had not been code read for about three years previously (it told me that).
    For our BMW I have the dealer level laptop based program comparable to the "STAR" one for Mercedes. It goes way beyond these handheld readers but 99% of the time is over the top. In fact I was so pleased with the capability of the iCarsoft i980 for the Mercedes I bought the iCarsoft model for my BMW as a glovebox tool in case of problems when on a long holiday run etc. A couple of months ago I used the iCarsoft to track down an obscure airbag issue on the BMW and then to prove 2 of the 3 used airbag ECUs bought on Ebay were faulty and get them refunded. Very impressed.
    I have the Foxwell NT500 which is broadly the VW/Audi/Seat version of the all vehicle NT624. It's a slightly larger and more rugged unit than the iCarsofts but as far as I've found has roughly the same range of abilities as the iCarsoft.
    So for a Mercedes, unless I knew I also wanted to diagnose other vehicle makes, I'd stick with the iCarsoft i980.
    DavyYoung likes this.
Share This Page
