Recommend me a Scrappy
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by fidge, Mar 15, 2017.
  1. fidge
    fidge Senior Member
    45
    Feb 14, 2017
    Sandwell, West Midlands.
    Your Mercedes:
    C-Class Coupe 2013
    I've just purchased my first DA Polisher and rather than go all guns blazing on my nice new car I want a scrap panel to practice on. I also want to practice my stone chip and scratch repair.
    Now ideally I would like a metal panel in the same colour, Diamond White.
    I'm in the Birmingham area, can anyone suggest a scrappy, local or otherwise that may be able to supply such a panel?
    There is a door in Wolverhampton, but they want £75 for it, which is too rich if I'm just going to destroy it.
    TIA.
  2. Big Cheese
    Big Cheese Senior Member
    52
    8
    Feb 22, 2017
    WEST MIDLANDS
    Your Mercedes:
    ML63 2007
    Try Autobits on Clarkes Lane Willenhall.
    Even though I deal in scrap I don't break cars but Darren there does
  3. V6Matty
    V6Matty Senior Member
    4,763
    120
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    Peugeot 508 RXH (His) W169/2005/A180 (Hers)
    Sounds stupid but give MSL a try, they did start as a parts supplier
  4. DREAMER NO2
    DREAMER NO2 Senior Member
    1,918
    107
    Dec 29, 2013
    Your Mercedes:
    W124 2.6E M103
    Hi you just dont polishing body work before checking that you have enough paint on there to do so .A special paint prep is the way to go .And they will know if its possible to bring the paint up to 100%. They have a tool to say just how much paints on the part thats to be polished .Is the paint work car original ? any new wings or doors .The paint wont be the same all over the car, if the pnels have been replaced before.
  5. OP
    fidge
    fidge Senior Member
    45
    Feb 14, 2017
    Your Mercedes:
    C-Class Coupe 2013
    Yep I know, I have a paint depth gauge to check the paint thickness.
  6. DREAMER NO2
    1,918
    107
    Dec 29, 2013
    Your Mercedes:
    W124 2.6E M103
    Right then you know all about it .so go ahead.
  7. OP
    fidge
    fidge Senior Member
    45
    Feb 14, 2017
    Your Mercedes:
    C-Class Coupe 2013
    I never said I knew all about it, but I'm willing to learn, hence the request for a scrap panel to 'play' with. :roll:
  8. OP
    fidge
    fidge Senior Member
    45
    Feb 14, 2017
    Your Mercedes:
    C-Class Coupe 2013
    He couldn't help me unfortunately.
  9. brianbrian
    brianbrian Senior Member
    2,295
    25
    Sep 27, 2008
    cockney in the West Country
    Your Mercedes:
    w124 250D, SL129-deisel
    Scrap merc body parts
    Southhamton large merc breaker.
  10. lwbnick
    lwbnick Senior Member
    1,300
    Mar 4, 2010
    wales
    Your Mercedes:
    expedition
    Just buy something cheap off gumtree.
    Failing that I've for some panels you can have for nothing if you can collect them.
  11. brianbrian
    2,295
    25
    Sep 27, 2008
    Your Mercedes:
    Old panel
    Any body works will give you a old panel to play with, as they pay to have it taken away.
  12. Xtractorfan
    Xtractorfan Senior Member
    5,985
    115
    Nov 16, 2007
    Your Mercedes:
    S class
    Practise on you bonnet or boot lid and stay away from the edges, you can tape the edges with half inch /12mm masking tape. this will stop you from rubbing thru on the edges.
    With a DA sander, you are likely to do less damage to paintwork.
    Start off on a slow speed, and then as you get more confident you can increase the speed.
    You will find that higher speed doesn't necessarily mean quicker or better polishing.
    Turn the speed down for bumpers and plastic, and dont dwell on the one spot, keep the polisher moving at all times, as slowly as possible, and you will see results.
    Never polish edges, let the polisher run over them at the end of the session. and never let the polisher feed into an edge. Get to know how the sponge pad runs, ie top half will run off an edge to the right, bottom half will catch the same edge, so tilt the polisher, so the bottom half doesn't touch the edge.
Share This Page
