imkaz
Hi All,
I wasn't planing for this to be my first real post, but I've run into a few problems and would appreciate some help.
I recently bought a CMR230 Remote Roof Module for my SL from www.cabrio-module.de on ebay.
Here's a link to the auction: http://www.ebay.co.uk/itm/361243007582?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I am having trouble knowing if it has been fitted correctly. There isn't a lot of information on its installation, but I think it works in a similar way to the popular mod4cars Smarttop module.
I used the CAN bus in the passenger footwell (left-side) of my RHD car. Instructions state to just remove the only black/black-brown wire and put the module inbetween to complete the circuit. I have also grounded the module and attahed to a 12V cable, I have used the slightly thick red/green one as I did not have a solid red cable or a red-purple cable as per the instructions. I have also checked the voltage of the module to ground and it reads a solid 12.2 ish volts.
I have tested the remote feature several times and it doesn't seem to work. As the default setting is to be in passive mode when installed, I have no idea if it is working, connected properly etc...
Any help would be appreciated!
