Restoring an old 180db Mercedes Benz (Ponton) from 1960. A barn find ?
Discussion in 'General Mercedes-Benz Related Discussion' started by anyweb, Aug 6, 2016.
  1. anyweb
    anyweb Senior Member
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
    w212,w120 (petrol),w120 (diesel)
    So I've decided to create a new thread for this, so others can find it easily. The original thread was here and didn't reveal what the car was.
    Long story short, I found an old Ponton, made an offer on it after being advised to do so from this forum, took a quick loan from the bank and then bought it.
    I've started working on it when I can and my aim is of course to make it road-worthy again. I'm starting with all the brakes as they haven't been in use for 30 years. So far I've removed only the rear brake cylinders and they were both in a bad state, one worse than the other.
    Today I spent many hours removing rust, cleaning up the brake cylinders, and honing the inside of the left rear brake cylinder before finally re-assembling both of the brake cylinders. Here are a few lo-res photos of that (lo-res because this forum software seems to down size the photos for some reason.)
    I've documented todays' work with a lot of high-res photos here and I hope you enjoy the results of my efforts.
    cheers !
    niall
    Jim2 and Mic like this.
  2. OP
    anyweb
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
    so today's job was to remove the front left wheel and get the brake cylinders out so I could work on them, sadly however the job did not go as planned due to my lack of patience, and lack of suitable tools.
    I couldn't remove the brake drum even with the bolt in the three holes trick, the bolt I had was too short, I couldn't find a replacement long enough, so i resorted to using a hammer.
    Big mistake.
    I ended up breaking off a rib of the outside of the brake drum so I guess that means I'll need to replace it, and that means sourcing a replacement (I live in Sweden) and buying one.
    Anyhow, I've also decided to try my hand at making a video about the car, and hope to do more of them (from time to time), here's my first attempt, it's a youtube video called First looks at a Mercedes Benz 180db from 1960.
    Please check it out and let me know what you think, go easy on me I'm new to talking about cars on video.
    I've blogged todays progress here with lots and lots of high resolution photos including a picture of the brake parts from a service manual.
    Below you can see a small selection of photos from todays visit to the garage, if you want to see more click on the blog link above.
    I did manage to get both brake cylinders out from the front left wheel in the end (what a dirty job it was) but like I said, I damaged the brake drum in the process, silly me.
    due to the damage should I replace both front brake drums or is it fixable (welding ?), or should i definitely replace it ?
    advice please !
    Jim2 likes this.
  3. rifiki
    rifiki Senior Member
    189
    35
    Dec 29, 2015
    Worksop
    Your Mercedes:
    clk W209 Ponton 190
    Brave man. Don't worry about a few broken fins, get the front wheels balanced on the car.
  4. OP
    anyweb
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
    ok so since I posted last time I've cleaned up the brake tubes from the front left wheel and removed the seized piston from one of the two brake cylinders.
    Here's a snippet of that activity:
    When I got home from work I felt like doing some work on the car, so I went into the out-house and found one of the two brake cylinders that I removed from the front left wheel last week, it looked well seized.
    and here’s another view showing the rusted outer protective cap which sits on the rubber sheath dust cover.
    This brake cylinder is a mess, and I’ve not encountered this outer protective metal cover before, as you can see its in such a bad state it’s got holes in it even before I’ve touched it.
    I tried to remove the metal sheath with gentle force and a flat blade screwdriver but it wouldn’t budge and the metal was very fragile, I feel it’s expendable but I’m not sure. Eventually I got it off but it cracked somewhat in the process, there was no other way, the rubber sheath ripped in two in the process too but that’s ok, I will replace that with a new one anyway.
    Just look at the state of the piston and the cylinder, it definitely looks like it hasn’t budged in 30 years.
    Here’s the protective metal sheath, you can see the holes clearly and the crack from the hole to the edge, I’m going to try and source replacements but on my other Ponton, the front brake cylinders only had the rubber sheaths so I don’t know why this one has this additional metal ‘cap’.
    read more with loads of photos > https://www.mb180db.com
    Jim2 likes this.
  5. OP
    anyweb
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
    am i right in that the brake cylinder should be 'ok' even with the visible damage on the lip of the brake cylinder, I will clean it all up and it will be covered with a new rubber sheath
    Jim2 likes this.
  6. turbopete
    turbopete Senior Member
    14,204
    301
    Feb 4, 2009
    Spennymoor
    Your Mercedes:
    2010 '60' Ford Mondeo 2.0TDCi Zetec (sorry)
    if you mean the damage near the outer edge of the lip on the cylinder, that will be fine.
  7. OP
    anyweb
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
    anyone know where I can buy this broken bit ?
    Jim2 likes this.
  8. OP
    anyweb
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
    that's exactly what I thought Pete, thanks !
    Jim2 likes this.
  9. ampwhu
    ampwhu Senior Member
    417
    5
    Oct 9, 2011
    New Malden, Surrey
    Your Mercedes:
    2004 W203 C200CDI Avantgarde se
    my neighbour has one of these in his garage. it has sat there since the 80's. he does run it every now and then.
    Jim2 likes this.
  10. OP
    anyweb
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
    ok this weekend I removed the brake drum from the right front wheel and I did it using the recommended method after braking a few fins on the front left brake drum last week, I documented this method in this video
    https://www.youtube.com/watch?v=VhtdAUyCF7c
    Once I had the brake drum removed, I set about removing the retainer springs holding the brake shoes in place, and the bolts and finally removed the brake shoes themselves. I created a youtube video of that too, and here it is.
    https://www.youtube.com/watch?v=fRedtrngpcI
    and then I set about removing the brake lines and brake hose, so that I could finally remove the brake cylinders from that wheel, it took some time but I got both brake cylinders out, here's a video of that.
    https://youtu.be/T26dXOnu5W8
    Jim2 likes this.
  11. rifiki
    189
    35
    Dec 29, 2015
    Worksop
    Your Mercedes:
    clk W209 Ponton 190
    broken bits
    Try niemoller mercedes, mbclassics.de, German Ebay and mercman.net
  12. OP
    anyweb
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
    i found a local place here in sweden that does that parts, niemoller also does the bit i broke on the piston....
    Jim2 likes this.
  13. OP
    anyweb
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
    so today I tackled the brake master cylinder, what a job, it took a few hours and the cylinder is very very very rusty, but I got it out in the end so that is a good result.
    Below you can see a few photos of the removal, I'm creating a video in Adobe Premier right now, and will upload it to youtube later, once done I'll add the link here as it has a lot of detail of how I removed the brake master cylinder.
    Jim2 likes this.
  14. television
    television Always remembered RIP
    164,074
    260
    Your Mercedes:
    Rusty was an understatement :D you did well there.
    Jim2 and anyweb like this.
  15. OP
    anyweb
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
  16. OP
    anyweb
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
    not sure if anyone is interested but I'll keep updating anyway in case someone is :)
    today I cleaned the outside of the brake master cylinder, it was in a state, extremely rusty and well, almost looking as if I'd need to buy a replacement. However I cleaned it up and the results were quite something, in addition I got the insides removed and am ready for the next stage, honing the brake master cylinder which I will do some time in the future.
    is it ok to leave the brake master cylinder in a diesel bath for a few days to soak the metal, or should I avoid that ? the rubber bits are all out of the diesel.
    here's loads of photos of the cleanup today > https://www.mb180db.com/2016/08/cleaning-up-the-brake-master-cylinder-and-removing-the-insides/
    Jim2 likes this.
  17. turbopete
    14,204
    301
    Feb 4, 2009
    Spennymoor
    Your Mercedes:
    I cant see an issue in leaving the metal parts in a diesel bath. not really sure why you would want/need to though.
    do check that the master cylinder hasn't become porous after removing all that rust etc. even though its unlikely, better to check now than when its all back together again finding it leaks/draws in air
    Jim2 likes this.
  18. OP
    anyweb
    2,739
    104
    Jul 15, 2005
    Sweden
    Your Mercedes:
    I want to because the outhouse I leave the bits in has a leaky roof and it's damp as a result, so even though I honed two brake cylinders so far, they are starting to show a thin line of rust on the inside of the cylinder
    I guess I could coat them (the inside of the brake cylinders) with brake fat ?
    Jim2 likes this.
  19. Cole@MBS
    Cole@MBS Forum Supporter Authorised Forum Supporter
    13,411
    410
    Dec 1, 2008
    Hedge End, Southampton
    Your Mercedes:
    124 300 CE 24 Coupe, 209 240 CLK
    I'm enjoying this thread Niall, please keep going, as you prob no, I love working on the older cars, not as old as your tho.......
    anyweb likes this.
  20. television
    164,074
    260
    Your Mercedes:
    Diesel does have good cleaning properties .
    Jim2 likes this.
Share This Page
