S210 resto project thread?
tjamesbo
Sutton Coldfield, West Midlands
1999 CLK430, 2007 VITO 3.0V6 , W124's (1994 320TE , 1993 220TE ) , 07 2.5 X-Type
Is the SLS filter the one in the top of the Hyd Fluid reservoir ? lift out and replace ?? or is there a finer filter somewhere else?
BTW behind rear bumpers on mine exactly the same
Boyd
Naraic
2005 CL500.
One of the reasons why my donor car was for breaking.
Sorry, couldn't resist :D.
They are non structural so you need the nearside one to hold the spare wheel , but the off side one could be a flat plate level with the floor of the boot.
O
om613
london
S202 C250TD, S123 240TD
  • #23
Boyd
Yes that's the only one.
It's held to the cap by the age-old 'sprung hook' arrangement, so it needs pushing up and twisting before it pulls off.
O
om613
london
  • #24
Springs
I didn't say much about springs in my to do list, so I will add here to keep it all together, although I've covered some in other posts.
Front:
The car sits too low for an AG spec: both sides are 33 cm from axle to arch, which is 2 to 3 mm less.
An old MOT shows it failed on a broken front spring. Possibly they've been replaced with incorrect / poor quality new ones, worn s/h ones...or maybe someone chopped the unbroken one to match, as they usually fail at the bottom about 2inches from the end.
OE AG spec. springs have four paint dots - 3 white, 1 yellow. I have the right spring comp, so they'll be coming off anyway.
Rear:
Here we have a mis-match in ride height of 2.5 mm. No broken spring ends were evident.
Maybe a ram fault, as they work together. Maybe I need to run the car more to charge up the SLS.
There is a rear end 'clonk' too, 'usual suspects' here - bottom ram ball joint, front body mounts etc. Some never find the source, it seems.
Ideally, I'd drop the sub frame and do the lot, plus hidden brake and SLS pipes include but that's probably not going to happen.:(
JBell
Torquey
C350 CDi Estate (GAD Edition)
Front:
Springs sag over time, they will never maintain the original ride height
turbopete
Spennymoor
im amazed you can even TELL the height is down (without measuring it) if its only 2-3 MM! it would drop more than that filling the fuel tank etc!
O
om613
london
  • #27
sorry, 2 to 3 cm.
Craiglxviii
Cambs UK
You should have kept quiet, we would all have believed you were a human micrometer then!
Frontstep
T210 320cdi
Look for rust on everything made of metal and you won't go far wrong.
Craiglxviii
Cambs UK
O
om613
london
  • #32
Some pictures and not before time.
The donor looks sad at its impending fate.
But will yield some drive space back for the others.
What a beautiful car you have there. :D:D
turbopete
Spennymoor
i know ive said it before, but a GOOD 210 is a FANTASTIC car
O
om613
london
  • #37
A brief update:
Now MOT'd and on the road.
New front discs bought as a Talisman that would encourage the 'warped' set to be nearly new but on unclean hub faces...
Plenty to do. The ridiculous front springs need to go asap.
Full ATF and pilot bush change after that, plus the brakes feel full of air.
O
om613
london
  • #39
They were the wrong ones, were mis-matched and one was broken, so were too low and too bouncy (there's another 210 springs thread of mine covering this).
Swapped them for the correct AG springs which are much better, spring rate-wise, but still a bit too low for the many speed humps we encounter locally.
The 4 'pip' spacers over the std. AG 2 pip would add another 10 mm ride height.
Which retrospectively, I would now do.
O
om613
london
  • #40
Another update for you all.
Brakes were indeed full of air. With new fluid and a bleed they are magnificent, as designed.
However, I have been a total knob.
I was "sure" that I had read somewhere on the exacting internet that an iCarsoft i980 was the ideal tool for the intrepid 210 DIYer, so I bought one, having a 38 pin converter/OBD lead.
It's a lovely tool. Maybach owners are covered... but not 'us'. Only diesels 2004 onwards.
