I have a 2013 ML 350 W166 and suddenly the sat nav units are in km, I have made sure all units on speedo are in mph and tried to find a menu to change it back to miles in the command menues but cannot find one, any ideas?
If it is anything like my E350 which is a 2011 car simply selecting left or right hand drive in the cluster under vehicle from memory it will change the pattern of the lights, units from mph to kmh and miles to kilometers.
Thanks for that I already looked at the settings and they were in mph. I have found if I then change them to km and back to mph the sat nav is then in miles, however its defaulting to km only on the sat nav at each switch off, so sounds like a software bug, or a setting somewhere else
