Sat navigation update w212
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Medntee, Dec 5, 2017.
  1. Medntee
    Medntee Senior Member
    479
    6
    Oct 21, 2010
    Midlands
    Your Mercedes:
    w220 s class
    Hi all
    I have a Mercedes e350 w212 2012 I've been told by a dealer that my car has to go in to Mercedes for sat navigation update is that correct or can I buy a disc
    Kristian
  2. malcolm210
    malcolm210 Senior Member
    2,872
    215
    Aug 21, 2005
  3. OP
    Medntee
    479
    6
    Oct 21, 2010
    Midlands
    Your Mercedes:
    w220 s class
    Wow mercedes only quoting me 110
  4. CowleyStJames
    CowleyStJames Senior Member
    87
    14
    Oct 13, 2015
    Oxford
    Your Mercedes:
    Mercedes-Benz C-Class Estate C200 CDI BlueEFF. Executive SE 5dr
    Comand online has always been expensive
  5. JBell
    JBell Senior Member
    8,211
    1,097
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    Nope, MB have a special offer on at the moment BUT you have to check it applies to your car, some on here have been quoted £200
    Alfie likes this.
  6. Alfie
    Alfie Forum Supporter Authorised Forum Supporter
    2,317
    78
    May 12, 2005
    Surrey
    Your Mercedes:
    If Mercedes are offering to do the update and get the pin code for £110 then bite their arm off. Its a good deal.
    CowleyStJames likes this.
  7. Mr Filipov
    Mr Filipov Senior Member
    598
    83
    Dec 31, 2015
    Huntingdon
    Your Mercedes:
    2014 BMW 530d Gran Turismo
    I did mine at Mercedes some 6 or so months ago at £110. Mine lives on the HDD of 4.5.
    The only annoyance was that they kept my car running while doing the update instead of hooking it up to a trickle charger like they should.
  8. malcolm210
    2,872
    215
    Aug 21, 2005
    Can’t believe they did that unless it was necessary for some reason. Isn’t the update circa 1hr?
  9. JBell
    JBell Senior Member
    8,211
    1,097
    Dec 9, 2011
    Torquey
    Your Mercedes:
    I just turned to COMAND on and stuck the disks in (NTG4), let it go, no need for trickle charging or to keep the engine running, took about 1hr 30mins, no issues at all
  10. Chrishazle
    Chrishazle Senior Member
    2,088
    118
    May 25, 2009
    Nr Ashford, Kent
    Your Mercedes:
    S204 2008 C220CDI Elegance Estate Auto, 1993 Porsche 968 Tiptronic cabriolet
    IIRC you need ignition on (pos 3 just before the starter motor kicks in) or Comand will shut down after about 10-15 mins. That happened to me first time I attempted an update, second time I left the engine running and the full NTG4 update took 2 1/4 hours hence my recommendation to connect a battery charger while updating - which I've done twice since but am now on V12 and can't go further (early NTG4 with small nav partition on HDD).
  11. malcolm210
    2,872
    215
    Aug 21, 2005
    Same here COMAND shuts down after 15mins so would have to use a trickle charger
  12. John Laidlaw
    John Laidlaw Senior Member
    13,757
    2,672
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    I just went for a drive when my SL’s new nav discs were updating- about an hour and a bit- all good
  13. JBell
    JBell Senior Member
    8,211
    1,097
    Dec 9, 2011
    Torquey
    Your Mercedes:
    I washed the car
  14. John Laidlaw
    13,757
    2,672
    Nov 15, 2013
    Wirral
    Your Mercedes:
    :p
  15. Botus
    Botus Senior Member
    2,031
    190
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    very risky.
    my car (not this system) does it in 45 minutes, the user instructions from merc specifically state to do it stationary with the engine running
    for any brand of vehicle - never try to do anything on a car with software without some form of additional power supply
    that really means diagnostic scanning too
Share This Page
