nidgemo
- Mar 5, 2014
- Location
- Northern Ireand
- E Class 220 CDI Avantgarde Nov 2008
Hi All
I recently (about 6 weeks ago) bought a 2013 (facelift) W212.
Within 20 mnutes of picking it up, the engine warning light came on, and it transpired to be a small electrical fault that was extremely hard to trace (a boost pressure sensor).
I must say, the independent (but very large) dealer I bought it from have been excellent to date in getting it sorted out, extending my warranty for another 18 months (on top of the 12 I got initially)
However, on getting the car back (eventually) from that repair (which took going to the dealer for 3 days, Mercedes for 9 days and an independent diagnostic for 5 days!) within another few days another fault appeared (Temperature sensor 1 Catylitic converter cylinder bank 1 has a malfunction. The signal is outside the permissible range)
The dealer got the specialist to come and look at it and (bear with me - long story, I know) he said because I do a reasonable bit of town driving, that sensors would keep failing.
(I am aware of the needs of a modern diesel with dpf etc, to take for decent drives etc, and make sure I do this - I bough a MBII sensor to read the dpf levels once a week, and, if it's getting a little high, I take it for a 60 mile A road and mororway run which takes it back down nicely)
The independent specialist then recommended I get the dpf bored out, ECU remapped etc, as with my driving style sensors would keep failing.
So, two questions...
1. Does this sound right? Even with me being aware of DPF soot level, checking it regularly and taking the car for a spin to clear it out? Surely in a modern, £15,000 car with only 60k on it, it shouldn't be the case that a bit of town driving during the week should be leading to continual sensor failures surely?
2. I'm not very keen to cause about £2000 worth of, essentially, damage to a £15k car... And would obviously be concerned at future MOT failure and having to spend that to put it back in... but, frankly, I'd also be glad to see the DPF, ECU and that whole bank of sensors gone too, as it's a balls of a system (and I'm not concerned about being ecologically friendly as, living in Northern Ireland, you should see the state of some of the messes and black smoke machines clogging up the roads over here)...
So, any advice, answers to the questions, thoughts, experience of having had dpf bored out and remapped etc and anything you have for me welcome!
