Silicone spray 500m on ebay
Discussion in 'Mercedes Goods on eBay' started by DREAMER NO2, Jun 27, 2017.
  1. DREAMER NO2
    DREAMER NO2 Senior Member
    1,915
    107
    Dec 29, 2013
    Your Mercedes:
    W124 2.6E M103
    Just had 6 tins of this silicone deliverd . Its a good deal for 500m tins x6 for £19-99 you can pay £6 a tin for it . Ideal for detailing the rubber parts, ie seals on the doors, boot , along with any rubber pipes showing ., Even the rubber bushes on the under side exposed to the damp .. ebay number is 272000605544
    00slk likes this.
  2. EmilysDad
    EmilysDad Senior Member
    5,330
    290
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    You mean some people have to buy silicone spray? :rolleyes:
  3. OP
    DREAMER NO2
    1,915
    107
    Dec 29, 2013
    Your Mercedes:
    W124 2.6E M103
    Emilys dad well its up to .I just posted this because i use silicone for a lot of jobs on my car.
    You dont have to purchase it. Or is it that you have a secret supply from the past ?
  4. BaronRidgeback
    BaronRidgeback Member
    15
    Nov 11, 2016
    Colchester
    Your Mercedes:
    R129/1999/M112
    Not bad, thanks for the 'heads-up' Dreamer.
  5. Frosty149
    Frosty149 Senior Member
    1,987
    435
    Jan 9, 2017
    Garden of England
    Your Mercedes:
    W207 '63 E350 coupe amg sport
  6. OP
    DREAMER NO2
    1,915
    107
    Dec 29, 2013
    Your Mercedes:
    W124 2.6E M103
    Thank you for thanking me .Just ideal for the rubber bits under the bonnet .And any other parts to shine them up .Buff off after to make an even shine.
  7. umblecumbuz
    umblecumbuz Senior Member
    2,703
    269
    Sep 20, 2010
    Wales and Gozo
    Your Mercedes:
    S204 and CLC 204 cdi, other non-Merc machines
    Having used Krytox and Gummi thingy in the past, I now use silicon spray for all door seals, with superior results. In frosty conditions, they used to stick, but now - no problems.
    Another use is to spray the pillars that the engine cover locates on, on most Mercs. These covers often are a pain to pull off, and one of mine split due to a hamfisted mechanic. I've tried all sorts of greases in the past, which worked fine for a while but always seemed to dry out. Silicon spray makes removing the plastic cover a doddle, and one spray a year is enough.
    Frosty149 likes this.
Share This Page
